3.4 to 3400 Top Swap help
  • Iyyob
    • Feb 2009
    • 25
    Its for my 95 OBD 1.5 Camaro cant use 3500 top and my tuning options are slim. I want it to be a badass motor what i need help on is the build. so its my DD but i want it faster. if money wasn't an issue what parts and specs would you use.
    Input what specs and why.i have never built a motor when i have all the parts im dropping it off @ the shop. the shop usually just does LS1s but he said if i got the parts he would put it together for me
    if someone makes custom rods/cam/piston ect list it with better specs i'll pay for quality i figure i might as well get the best while its apart.
    Heres what i have so far
    ECU/Fuel MGT
    Jet2 (i got it with a turbo kit)
    but i was thinking Mega Squirt
    TB
    3400 Stock
    Fuel Rails
    3400 Stock
    Injectors
    3400 Stock
    UIM
    3400 Stock
    LMI
    Gaskets
    Metal Intake Gaskets GM
    Pistons
    ???(saw some in another thread but have no idea what to get)
    Rods
    Heads
    Lifters
    Rockers
    Valve Springs
    Camshaft
    any other parts im missing
    (i do have a turbo BoV wastegate and stuff in my trunk but i think N/A would be better .. if u got any ideas for a turbo build that would be great also mabe we can get a "Best Of " and make it a sticky
  • Iyyob
    • Feb 2009
    • 25
    Show no love to the 'Best of " ....
      • 13522
      ECU/Fuel MGT
      Jet2 (i got it with a turbo kit) <--trash
      but i was thinking Mega Squirt <--sure, or a tunable GM OBD1 setup or other aftermarket
      TB
      65mm billet or aurora
      Fuel Rails
      3400 Stock
      Injectors
      28# 4.2 Trailblazer
      UIM
      3400 Ported (WOT-Tech)
      LMI
      3500 Ported (WOT-Tech)
      Gaskets
      Metal Intake Gaskets Felpro
      Pistons
      Stock for NA is fine.
      Rods
      Stock with ARP rod bolts will do just fine for NA
      Heads
      3500 Ported (WOT-tech
      Lifters
      Flat tappet...don't know.
      Rockers
      Stock until Scorpion Rollers are released
      Valve Springs
      Depends on cam
      Camshaft
      Something meant for high compression, so fairly large. Raise idle some and its good for a daily.
      A "best of" list is only useful for each application. The above may be totally wrong for what you really want, but its what I would do with your car in a daily driver with your bottom end. Also, NA doesn't require the best of everything. You can have rods made and go forged pistons but its just a waste of money when we know stock holds up just fine with ARP hardware on the rods.
