3400 TB on a 3100
  • carsan57
    • Sep 2007
    • 18
    3400 TB on a 3100
    I got an 01 gp with a 3100 i stuck a 3400 TB on it and had a bunch of problems, shifting was bad and it would not down shift at all.
    I thought it was a direct easy swap, some info on whats wrong would be nice,
    I put the3100 back on and it ran fine.
    Is it even worth putting the 3400 TB on it?
    • 13467
    Did you swap your sensors? They are identical minus size, 52mm vs 56mm. If the 3400 had bad sensors, then that is the problem, not the TB.
    • carsan57
      • Sep 2007
      • 18
      No I didnt switch the sensors, I'll give that a try.
      Is it worth putting the larger tb on
      • MidnightriderZ24
        • Jan 2005
        • 699
        yes it is. very worth it, considering its just removing and replacing the part.
        [SIGPIC]
        12.268@117... 11's to come!
        • Azrael
          Accelerating uphill in OD
          • Apr 2005
          • 763
          Don't the large-port 3100's and 3400's have the same size TB? I thought it was only the older, small-port ones that had 52mm TBs.
          1995 Grand Am SE
            • 13467
            All 3100 are 52mm
              I'd say the TPS on the 3400 one was bad. Swap your 3100 TPS over and it shoudl be good.
              • carsan57
                • Sep 2007
                • 18
                yep i guess it was, changed the TPS and it runs great, thanks everyone!!!!!
