why does my 3.4 swap feel weak??
  • 1986
    • Mar 2008
    • 41
    i just got done drive my 92 s10(5sp) for the first time, and i am not too impressed witht the power it is putting out
    heres what i got, fully rebuilt bottom and top, 3.4 camaro motor. 2.8 intake bored for 4.3 tbi and injectors, its got a small isky256 cam proper valve springs, k&n stock replacement filter,
    stock 2.8 manifold and full stock exhaust. this is all being run with the stock computer,
    i feels and sounds like its running fine but not as powerfull as i expected. feels weaker than all the 2.8s ive owed?
    do i need a custom chip?headers?full exhaust?
    s10s ive owned
    87-2dr 2wd blazer 6/7 drop-sold and missed
    82-s10 pickup long bed-sold thank god
    86-2dr 2wd blazer 6in. lift 31" tires-sold
    92-s10 pickup ext cab3.4L-6/7 drop
  • OldSkoolGP
    That guy over there
    • 930
    Why are you using so many 2.8 parts on a 3.4 camaro motor? Wasn't the point of using a 3.4 camaro motor that you wouln't have to worry about finding intakes and exhausts that would work on it?
    If you're using 2.8 intakes and manifolds on a 3.4 motor, you are starving it for air and keeping it from getting rid of all its exhaust gases efficiently. The biggest throttle body in the world won't make a difference if you have restrictions downstream. Why don't you try putting the 3.4 camaro parts on there, or at the very least 3.1 camaro parts so that engine can breathe?
      • 13531
      The computer is probably most of the problem. It has no idea that its not a bone stock 2.8 and can't possibly adjust itself for the TB. Bore and stroke increase will certainly need tuning.
      • 1986
        • Mar 2008
        • 41
        this exactly how every one with this swap runs it on their S10s, maybe im just expecting to much from it.im looking into a custom chip.
        s10s ive owned
        • geoffinbc
          Iron Head Enthusiast
          • 5831
          What are the cam specs? Double check timing and maybe do a compression test to verify all the valves are adjusted correctly. A first gen 2WD with a 3.4 should knock off a high 15 or low 16 quarter mile. I can do a 16 flat and that is with stock exhaust and air cleaner. I have a cold air intake now so it may go a bit faster but I have not raced it since. I also have a stock Camaro cam
          • 1986
            • Mar 2008
            • 41
            sepcs are 256duration in & ex, 425 valve lift 112 LSA, im pretty sure valves a adjusted right, maybe i just need it to exhale a little better.
            timing is set to stock spec,10* if that has anything to do with it,
            s10s ive owned
            • geoffinbc
              • 5831
              And you set base timing with the timing wire disconnected right? Other than doing a quick compression test to verify cylinder pressure the engine should run really strong even on a 2.8L chip.
              • 1986
                • Mar 2008
                • 41
                yes wire disconnected, maybe its is running strong and its just me thats expecting way to much from it, it sound perfectly healthy doesnt bog, hesetate or anything. im gonna drive it again right now.
                s10s ive owned
                • geoffinbc
                  • 5831
                  Well the 3.4L is not going to change your world. But it will move your truck quite a bit better than the 2.8L did.
