'03+ Crane gold rockers?
  • 95SleeperAcheiva
    ArtofOlivia"PocketRocket"
    • Jun 2006
    • 694
    So anyone got a part number on them? Anyone else make them other then crane? Does something else cross over from another chevy?
    • 13531
    no to all those. Until scorpion has time to do our rockers, we are SOL.
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      You could use ARP 8mm to 3/8" conversion studs but then I think your screwed for guide plates unless you bush them for 8mm studs. Or drill and tap your heads for 10mm to 3/8" conversion studs. Use gen II guide plates and then an aftermarket narrow body rocker arm with hardened pushrods. Slight LIM clearancing is required for most aluminum bodies rocker arms. Harland sharp has 1.65 ratio rocker arms but I have not seen anyone use them yet on a 660.
