Bottom End Questions
  • Nick-G
    11's or Bust...
    • Feb 2008
    • 224
    I'm going to be taking the bottom end of my 3400 apart soon so I can bring my crank to a machine shop and I'm wondering if I need to replace my arp rod bolts and my main bolts? Or should I purchase a bolt stretch guage to make sure they are not stretched?
    Another question I have is since I'm already having my crank brought into a machine shop should I just buy arp main studs and bring the block in to have the mains line bored and honed? I'm planning on running around 20psi on my turbo 3400 so I'm just curious if you guys think I should upgrade to main studs or just keep the new factory bolts.
    BUILT Turbo 3400/4t65e-HD powered Grand AM in the making.
    • 13533
    You have ARP main bolts? I wasn't aware they made those other than perhaps a custom order. 20 psi, I would use the main studs.
    • Nick-G
      11's or Bust...
      • Feb 2008
      • 224
      Sorry I kinda typed that in a hurry without reading it. I fixed it now they are new stock bolts. Anyways i'll probably end up going with the studs.
      As for my rods do the arp bolts on my eagle rods need replaced after being removed?
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        Rod and main bolts should not need replacement unless they were over stressed perhaps from detonation or extreme over revving.
        • 95SleeperAcheiva
          ArtofOlivia"PocketRocket"
          • Jun 2006
          • 694
          oops wrong spot
