does anyone know if u can port a 3400 top intake to be the size of a 3500 stock?
just another question
Tags: None
if i remember correctly, if you know what you're doing you can get a 3400 top to flow as well as a 3500.Originally posted by 01pontiacse View Postdoes anyone know if u can port a 3400 top intake to be the size of a 3500 stock?
oh ok yea its cause theres a machine shop that works on porting and stuff around here where i live and i wasnt sure if u could do that on the manifold without first asking the guy there at the shop thanx for the answer
oops, i read that wrong. i don't know about port sizes, although what i said earlier about flow should be right?
no, the 3400 cannot flow the same as a ported 3500 upper if you use the larger 3500 gasket size. The 3400 upper should not be ported to this size at all.Ben
i meant a ported 3400 compared to a stock 3500 upper.Originally posted by SappySE107 View Postno, the 3400 cannot flow the same as a ported 3500 upper if you use the larger 3500 gasket size. The 3400 upper should not be ported to this size at all.
thats what i thought...
how much room for improvement is there on a 3500 compared to the 3400?
2.68 sq in vs 2.28 sq in for the port size at the top of the runner.Ben
