boost with 10.5:1 compression?
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    #31
    Hey every mom that can cook cookies are worth a damn in my book...
    mmmmcookies....
      #32
      BillS: iron heads won't take as much boost as aluminium before knocking. And I'm not so sure a fuel cut on your motor when it starts to knock is a good idea under boost. That's a good way to start knocking more and melt pistons!
      • 95SleeperAcheiva
        ArtofOlivia"PocketRocket"
        • Jun 2006
        • 694
        #33
        lean is mean, rich is safe.
        • ghrarhg
          • May 2005
          • 215
          #34
          Just add a little Toluene to every tank
          • Alxsmt
            that one guy
            • Feb 2007
            • 725
            #35
            xylene works good too i guess. a guy at work used to race and make his own gas. increases octane AND it burns hotter
            • sprucegagt
              Old School KI
              • May 2005
              • 703
              #36
              Lowering the CR for boost is old school thinking and is a thing of the past.
              That all depends on the amount of boost you want to run. If he is at 10.5:1 compression, then I wouldn't recommend any thing over 5 lbs of boost on a street vehicle.
              Your local OBDII moderator
              2000 Grand Am GT w/ WOT parts
              • torq455
                If I only had money!!!
                • 1615
                #37
                we can throw in engine coatings too.
                Andy
                fastest 1/8: 10.19@ 67.17
                fastest 1/4: 16.16@ 82.70
                • BillS
                  • Oct 2005
                  • 132
                  #38
                  When the injectors shut down, you don't get a lean run condition (which would trash pistons) you get a no run condition - the fire goes out and doesn't come on again until you lift off. Wondered what the heck had happened first time I hit that, believe me! Miller Woods used that system and it seems to work just fine - not that you are bouncing of the limit all the time.
                  • 1988GTU
                    LB62LHObbqftmfw
                    • Nov 2005
                    • 2475
                    #39
                    I'm willing to risk as high PSI as I can get as long as the tune is within a safe territory. There really is no magic number seeing how every engine takes on detonation differently.
                    • Alxsmt
                      that one guy
                      • Feb 2007
                      • 725
                      #40
                      new issue.. my engine bay is smaller than i thought.. i dont even think its possable to mount one where the AC goes.. took a few measurements to compare to different chargers
                        #41
                        Talk to mars_man and see if he can get you some pics of his setup.
