CR headache
    • 13534
    same here
    The 206/206 @ .050 lift 260/260 seat to seat duration cam with .480 lift works fine on a stock 94 ECM. 91-93 3.4 DOHC ecm and code will run a 4T60E though I never did try a 94 trans with more sensors. Shouldn't be a problem if he wants to swap the ECM, but there are options on a stock computer. Proven.
    • torq455
      If I only had money!!!
      • 1615
      isn't the emission test done at idle? if so, having the EGR disabled won't matter, as long as it's connected.
      Andy
      fastest 1/8: 10.19@ 67.17
      fastest 1/4: 16.16@ 82.70
        many states do a rolling test too.
          okay, thought i would chime in with my INFINITE WISDOMZ...
          with a 4t60e he can run
          2E(which is what he has, just needs to run/pay for tunercat or make a def for TP RT)
          DF(remove the MAF, add a MAP(if necessary)
          1FA(A-Body so it has MAF, and technicly its not an older PCM than what he has, so i don't thats gonna fail an emission inspection)
          i don't know much about obd2, so i couldn't help with options there...
          • torq455
            • 1615
            ahh, haha, so much for that!
            Andy
            • aedden1
              • Jun 2009
              • 8
              #21
              Lots of interesting and potentially usefull info here. I had not really intended on a pcm swap, but i may ultimately have to. I cannot find a hacker willing to work on mine, and eventually i want to install a 5spd manual. I have figured a way to simulate the PNP circuit, but the TCC and shift servos have me stumped. I may have to find an ecu from a 93 Grand Prix, or a 94 Sunbird/Cavalier. Where to find in depth wiring prints to do this? I live in Montana (Montucky?) so emissions arent a huge issue. Just want reliability and no MIL.
                well, i would be one to talk to, i got the 94-95 3100 cars to run a 91-93 3.4 PCM correctly. i'm sure i could get the 94-95 3.4s to work with it as well...
                although if you want to spend the $20 for the TDF from tunercat, we can get it working in tunerpro... and apparently there was a manual tranny option in the 2E definition...
                http://tunercat.com/pdfs/ecm_$2e.pdf
                • aedden1
                  • Jun 2009
                  • 8
                  #23
                  After reading your thread on the OBD1 swap, it seems like you posses more info than my swap could ever need! I wonder if you could suggest a good ecu for the swap and some wiring diagrams? If you could supply one of your newly minted swap harnesses, i would surely be interested! I normally work the hardware end on cars, and dont have indepth knowledge of the electronics, just learn to keep what I have working. The obd1 is easier to tune for engine and FDR modification, isnt it?
                    tell you what, send me a PM(with everything you know/want to do) tomorow morning, its midnight here, time for bed
                    • geldartb
                      The Situation
                      • May 2004
                      • 1994
                      #25
                      my state did away with emission testing cars 95 and older. they did that since the figure most people have a 96 or newer car anyway.
                      one of the reasons they did that was because the dyno machines they use for it were wicked expensive.
                      99 Grand Am GT
                      1357 cam 227 233 .050 dur
                      515 515 lift 112 lsa
                        MA is still massachustes(?) right? i'll be sure to keep that in mind...
