Camaro 3.1 pistons in a 2000 3100
  • berlabs
    1987 Z24
    • Jun 2009
    • 16
    I know this will work but what will the compression ratio be? Anybody have some part numbers?
    What about some metal head gaskets?
    Hmmm. ran it through the compression calc, and it seems its 11.14:1. Not too bad.
    A 3400 with 3.4L iron head pistons in comparision is 12.39:1.
    EDIT, 2nd try.
    3100 with 3.1 rwd pistons and .040 3.1 headgasket and 3400 28.6cc heads = 11.4:1 with .057 quench which isn't too far off the 3500 stock quench. Cool.
    But this raises the question that according to the calc 3400 heads have a larger combustion chamber to keep the compression the same after the increase in bore. So that means if you put 3400 heads on a 3100 it lowers the compression to about 9:1...
    Does that mean 2000+ 3100 heads have a different casting # than 3400 heads to keep the compression up???? What gives?
      • 13525
      I have info there at the top regarding the different pistons.
        So is the calc wrong on the piston dish being the same for the 3100 and 3400 and the heads are the same or????
        • XLR8ING
          Too Stupid To Quit!
          • 268
          I ran the 3.1 iron head pistons years ago in my 3.1 MPFI. If I remember correctly, it was 11.3:1 compression. Number H562CP rings a bell
          Franz
          1990 Z24-NA 3.1L
          14.72 @ 92.24 MPH
          14.89 @ 94.92 MPH
          The boost is coming....
