2005 vs 2007 ecm's
  • 20-inch-bike
    • Jan 2009
    • 32
    2005 vs 2007 ecm's
    i have a 2005 3.5 w/wiring, and ecm im trying to put it in my sand rail how ever i was told the ecm is completely programmable and its not.... the 2007 version is... same motor are the ecm's interchangable???? i tried looking at the sensor specs and will continue to dig but the some of you might wanna know
    • 13534
    Different motor. The 2007 3500 is VVT and the 2005 is not.
      you could run the 3500 with a harness and computer from a 3400 Grand Am if you want to stay OBD2.. you would need an external crankshaft trigger and a few other things to make it work.
      Personally i'd use an old Cavalier harness and ECM, 100% tuneable and no added BS.
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        There is also a stand alone option which will be 100% Tunable with easy to use software
        • 20-inch-bike
          • Jan 2009
          • 32
          i dont want an external crank trigger and in 07 its the same motor no vvt " as ive been told" with a caviler harness and ecm is there an external trigger?? and id like to stay with a delphi ecm and would even be able to scan through the obd2 system... the 07 ecm is none to be even more tuneable then prior ecms.. but has anyone used one before... and what year caviler?
            • 13534
            What?
              What?
              seriously, i didn't understand a whole lot of that....
              HPT should support both ECMs...
              i would check......... but..... ok, i'm lazy.
                i run the external trigger system from TCE on my '04 3500 and the original 91 Cavalier harness / ECM with no problems. with a eprom emulator from Moates and Tunerpro RT (free) i have full access to anything in the ECM.
