Full roller rockers 3400!!!!!
  • gectek
    Banned
    • Aug 2006
    • 1472
    #31
    I am particular and there are only 2 3500 that have a diff rocker design that is not an OHC engine. I work at gm.....and i did the orig investment and the started the motion, so i have done my homework.
    trust me the rocker manuf will not do anything above and beyond their means. period. i have found that out. money talks alot. they will only do what they are paid to do.
    • gectek
      Banned
      • Aug 2006
      • 1472
      #32
      any update on this?
      • asylummotorsports
        Banned
        • Oct 2005
        • 649
        #33
        No one doubts that this would be a relatively small market and a break even project at best.
        BUT the tease has been here for almost a friggen year!!
        I have my $400+ set aside, 'cause that will likely be the final price tag, however it IS very frustrating!
        • 95SleeperAcheiva
          ArtofOlivia"PocketRocket"
          • Jun 2006
          • 694
          #34
          I go see them this Thursday. I received bare heads, LIM and VC's from a charitable 60 deg member, purchased 1 new valve, spring, and retainer set, and borrowed a rocker from my Achieva.
          I would like to discuss the clay and your results on the velocity testing of the test heads I received!
          Some interesting quirks there.
          So I'm taking the hardware above with me, some of the listings for the more radical cams available for max values, and the specs on all the valve springs that may be used too. I'll post Thursday night on how it went.
          • latemodelnewbee
            • Jun 2007
            • 227
            #35
            correct me if I'm wrong but can't you just big block chevy or small block chevy rocker with the 7/16" studs by just drilling and tapping the head for the 7/16" stud or is that just the iron head motors?
            68 El camino 454 speed muncie 3.90 posi 12 bolt,
            80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
            60 Impala 2 door hardtop L79-327 T56 4.11 posi.
            83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
            91 Z34 now has a hm284. and belly pan in the works
            • Firehawk94
              Fbody Fiend
              • May 2009
              • 179
              #36
              Any updates?? You said you were going to see them last Thursday....it is now Tuesday. Whats the word, yo?
              94 Firebird 3.4 DD
              252000mi. All original
                • 9191
                #37
                No. The only rocker that would possibly work would be SBC narrow body rockers.
                • torq455
                  If I only had money!!!
                  • Dec 2003
                  • 1615
                  #38
                  It's the center bolt rocker covers used on the late 80's 350 TPI. They sure do look the same!
                  If you're talking drill and tap, then you'd have to go to a machine shop. I wouldn't trust my hand in getting things straight.
                  Andy
                  fastest 1/8: 10.19@ 67.17
                  fastest 1/4: 16.16@ 82.70
                  • no_doz
                    • Sep 2005
                    • 912
                    #39
                    just tell them that things like this could very well help lead to the 60*v6 uprising, since the only reason people seem to think the l67's are so great is because of the gobs of aftermarket caused by stock supercharging...id say no less people have 3100's & 3400's than have those crappy boat anchors-& id people could deck them out & beat on sbc's without swapping engines i wouldnt be surprised if a lot more people stop the v8/l67 swap crap & just build their stock motors.
                    in an ideal world... hey a guy can dream cant he?
                    • latemodelnewbee
                      • Jun 2007
                      • 227
                      #40
                      Yeah I diffinatley know it will machine shop work especially if I can remember right its not just drill out the 10mm hole to 7/16" hole but you have to drill it offset
                      • Weston19
                        • Mar 2006
                        • 48
                        #41
                        Why do you need an offset at all? unless your changing pushrod angles it should be drill and tap? 10mm= .254 7/16=.4375.... Will there be enough material? The only thing i can think of is making sure your spindle axis is on the same axis of the hole being drilled?
                          • 13531
                          #42
                          No way, you won't fit a rocker arm that uses that size bolt. Splayed valves makes the rocker arm choices more difficult. Changing geometry isn't even feasible.
                          • latemodelnewbee
                            • Jun 2007
                            • 227
                            #43
                            I think I'm refering to iron head its been a real long time since I seen, it been a long time since I messed with pushrod 60* last few years the 60* I messed with was a LQ1 other than its all buick v6's (not 3800) and chevy v8's
                            • asylummotorsports
                              Banned
                              • Oct 2005
                              • 649
                              #44
                              OK! So I'm an idiot, and I search Summit and punch in 2005 LX9 3500, and it kicks out Comp full roller rockers # 1602-12 with a 3/8" stud and 1.6 ratio.
                              Just what all is involved, and DON'T start flaming!
                              Just asking.
                              • gectek
                                Banned
                                • Aug 2006
                                • 1472
                                #45
                                looks like they wont work.....sorry.
