TCE crank trigger vs. other options
  • 92cavquest
    • Feb 2008
    • 150
    I would like to buy a TCE external crank trigger but I'm looking to explore other options aswell. I know at one point in time someone was making a replacement ring that pressed on. Are there any other options? Does anyone know when the TCE unit will be back in stock?
    Any help is appreciated.
  • asylummotorsports
    Banned
    • Oct 2005
    • 649
    It's a damn shame they can't keep up on these things because they work brilliantly.
    I have over 1000 1/4 mile runs on mine and except for the lack of a bit of Loctite, it has never been a problem.
    • jdv
      • Mar 2006
      • 29
      This is a low cost set up.http://www.fiero.nl/forum/Forum2/HTML/101029.html
      More detailed http://www.fiero.nl/forum/Forum2/HTML/103834.html
      • 92cavquest
        • Feb 2008
        • 150
        That does look pretty cool, but I'm tired of fabricating. I'd like something I can just buy and install for once. I wonder if I can get someone to make it for me. LOL
        Has anyone actually tried it in a FWD platform?
          Check his sig
          • 92cavquest
            • Feb 2008
            • 150
            Not the TCE, the "other" one.
              Ah, ok, ignore me then
              • 1988GTU
                LB62LHObbqftmfw
                • Nov 2005
                • 2475
                um how do u download from the file den? I registered and it still fails.
                • gar70614
                  • Oct 2008
                  • 330
                  altgho suporting wot-tech would be ideal there are a couple other places that sell them at the same price. if u would still want the trigger. this is in no way ment to bash or put down wot-tech, they seam to be a awsome company they just happen to be out or triggers.
                  u could try right from tce.
                  Discover the latest in motorsports with the TCE Motorsports Blog. Get expert insights on performance upgrades, tuning tips, and racing news to elevate your driving experience.
                  or here.
                    • 9191
                    TCE makes the triggers and supplies WOT-Tech. The reason WOT-Tech is out is because TCE hasn't had the time recently to make another run of them. Same goes with BCC...
                      I have the TCE trigger, it's top notch quality. I'm sure they'll be back in stock soon.
                      • CNCguy
                        Bisong eater :P
                        • 1017
                        They will be back in stock within a few days. We have one more operation to do and they will be finished.
                        I am designing a new mount that uses a fixed CPS location. Although it won't have the timing adjustment, it should be a little cheaper.
                        I had considered offering a replacement ring but feel that the majority of people prefer the option of not needing to disassemble their engine to put one in. Getting a ring mounted in the proper location is also an issue. The external wheel saves time, work and eliminates the chance of improper installation.
                        MinusOne - 3100 - 4T60E
                        '79 MGB - LZ9 - T5
                        http://www.tcemotorsports.com
                        • jmgtp
                          • 1219
                          I think I got the last one from WOT-Tech a few weeks ago.
                          The TCE unit really looks like a top notch piece.
                          I do have one mild concern... seeing how the reluctor wheel and CPS are now going to be external to the engine is there any risk of foreign debris damage? I don't mean impacts as much as the accumlation of dirt, grease, metal particles, etc?
                          I'm not sure if it came with any instructions. Install seems simple enough, but, is there a shimming process to get the right clearance between the CPS and reluctor wheel - or should it be dead on as is?
                          1994 Corvette
                          LT1/ZF6
                          2006 Dodge Dakota 4x4
                          3.7/42RLE
                            • 13534
                            Should be dead on as is. Stock is in a bath of hot oil, so I think this external will be fine. Its a magnet/metal deal, so not much of an issue for dirt and grease until it contains a lot of metal.
                            • asylummotorsports
                              Banned
                              • Oct 2005
                              • 649
                              Mine may be one of the longest running ones and the only issue I have ever had is me not loctiting the damn thing to the engine and it FINALLY came loose and cost me a sensor. AFTER THREE YEARS!
                              And I have never really bought into the adjustable timing element. The computer would likely just correct it no matter where you set it.
                              My .02
