3500 cts?
  • gar70614
    • Oct 2008
    • 330
    3500 cts?
    my 3500 is runnin on a 99 grand am pcm and ideling at like 2500 rpm. i realized its prob because the pcm shows temp at -38 degrees. seams to be a problem lol. im using a brand new cts for a 3500. should the ga pcm be able to read the 3500 cts or do i have a wiring problem?
  • geldartb
    The Situation
    • May 2004
    • 1994
    im using the 3500 coolant temp sensor on my 99 grand am and mine runs fine.
    never had a problem with it. its a 2 wire sensor like the Grand am is.
    3500 top swap and i just went and bought a CTS from GM for a 2005 G6.
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
    • gar70614
      • Oct 2008
      • 330
      yea its a two wire just like a ga but the threads r smaller. ok good to know ir works i might just have a wire crossed or somethin.
        • 13532
        Correct, and I just listed the CTS extension for the 3500 sensor using the 3400 wiring harness. Both 3400 and 3500 CTS have the same resistance values.
        • geldartb
          The Situation
          • May 2004
          • 1994
          i still have the old hook up in my injector harness. all i did was run a separate wire like it was done in the factory.
          it was easier this way for me since i already had the wires separate from another harness.
          you can see it in the pic here. it was long enough to reach the sensor and i didnt have to disturb the harness on the car.
          the sensor is cheap from gmpartsdirect. iirc it wasn't more than $20 for the sensor.
          99 Grand Am GT
          • gar70614
            • Oct 2008
            • 330
            how would i go about finding out the resistance of a sensor. i think i may have found a three wire that will fit but want the check to make sure it will read correctly after i verify the thread is in fact correct. could i put a ohm meter on it and then a 3500 one that are both at the same temp and see if the show pretty close?
            • finalcount09
              • Dec 2010
              • 26
              Yes you are correct. If they are about the same temp, they should ohm out about the same.
              • boomofdoom88
                • Oct 2010
                • 111
                I used a 3400 CTS and just Tapped my 3500 lim for it. Uses a 3/8 npt tap. Simple to do and wont require any modifications to the harness
                • 2.8-350TBI
                  RWD FTW!!!
                  • Sep 2009
                  • 350
                  You may want to check the wiring to make sure it isnt grounded or shorting out anywhere too...
                  Originally posted by Mars
                  Haha ^ Wrong Wheel Drive.
                  No 60šV6 at the moment
