Fiero 2.8, change to carb and to hei distributor
  • lambo2.8
    • Dec 2009
    • 3
    ok guys i know you are going to rag on me here, but i have so many questions about these 60 degree engines that i don't know where to begin.
    i have an Lambo countach kc, donor 85 gt fiero, i want to put the biggest valves i can in the 2.8 iron heads, carburate it (biggest holley that will work) and hei dist. yes i know i can do an engine swap but, i would like to work with this 2.8!
    please any correct input would be welcome:>)
    • 13531
    What you have is what you get as far as heads for a carb right now. Only iron heads had carbs.
    • lambo2.8
      • Dec 2009
      • 3
      ok, i will be buy the Edelbrock # 3785 & # 3789 intake. will this work with the fiero 2.8 iron heads?
      • savannaz34
        • Jun 2008
        • 72
        why bigger heads?i thought the bigger the heads= less compression.smaller heads=more compression(ratio).am i wrong?
        • lambo2.8
          • Dec 2009
          • 3
          ok not bigger heads, bigger valves. sorry!
            i think by bigger, he meant valves/ports, not the chambers...
            • carbon
              Procrastinator
              • 388
              The biggest valves from GM are the valves in the high output head, which are what the Fiero has stock. If you talk to/look up user Oreif on Pennocks Fiero Forum he had managed 220 crank HP 2.8 running a carb. Porting and polishing the iron heads, a cam and a better exhaust system will be needed to get to that power level.
              edit:
              Found this 3.4L carb'd VS. 3.4L EFI Results by Oreif.
              - Ben
              • blownarrow
                FWD isn't that cute?
                • Oct 2008
                • 160
                Well so far I think I'm running the biggest "tune-able" carb on the forum...
                I'm running a holley 2v 500cfm on a 2.8, It's my daily driver and it pulls hard and runs good..
                the 2.8's a good little motor and it doesn't get enough credit, even form this group of weirdos.. there all hooked on Alum heads, efi, and boost.. ugh
                So you may not get the "good first hand" info your looking for here.
                There's a few die hard Iron head, and carb guy here but there few and far between, and offten weirder then these other guys...
                Good luck on your build and I give you a thumbs up in keeping it real..
                Do you plan on swaping your cam? If so Engle has some good Carb cams for
                this motor, also going to a 1.6:1 rocker out of the 3100 helps..
                Your limited on your valve size due to the bore.
                sigpicWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
                  lol!
                  I had a carbbed 2.8 once, it would still spin the tires of my '82 S10 with 224K miles.
                  gas mileage sucked and it really did not like cold weather starts. I sold the truck and shortly after that the oil pump failed and it ended up in the junk yard.
                  • jerome
                    • Apr 2009
                    • 17
                    Hell yes another carbed 2.8, Im running a 08007 holley 4 barrel 390 cfm on mine right now with an Edelbrock cam, does pretty decent. but Im still planning on a 3.2 boosted t3/4 set up running about 9-10 psi so ill play the fence on the subject on which route to go. but for now I would definitely put a cam in that motor and maybe port the heads a little when you have it pulled down.
