Will mrz pulley fit on a 05 impala 3400
  • kirk1989
    • Dec 2009
    • 2
    Just wondering if the mrz underdrive pulley will fit on a 2005 impala 3400 ? just wondering because it says baretta , lumina and corsica on the web site ?
  • 92cavquest
    • Feb 2008
    • 150
    I'd be willing to bet no. They told me they wouldn;t fit a 2002 Grand Am either. I wish someone made them.
    • kirk1989
      • Dec 2009
      • 2
      pulley
      thanks for the info .
      • geldartb
        The Situation
        • May 2004
        • 1994
        are you talking about this one. its the crank pulley
        i wouldnt run it on my engine. theres no dampener built into it like the factory one but its your engine so do what you want.
        you do realize its not vehicle specific right.
        99 Grand Am GT
        1357 cam 227 233 .050 dur
        515 515 lift 112 lsa
          • 13522
          I don't see the 24x ring, so it won't work with SFI computers.
          • geldartb
            The Situation
            • May 2004
            • 1994
            Ben i think its the same deal as the FFP ones were where you have to put the ring in yourself.
            either use the ring from your pulley on the engine now or get one off ebay or a scrapyard.
            thats what i had to do with the FFP pulley i had. put the ring in and never used it then sold it.
            its got the same 3 screw holes that the FFP one had to hold the ring in.
            same deal as the one i used to have
            99 Grand Am GT
            • 92cavquest
              • Feb 2008
              • 150
              My apologies, I was speaking about the alternator culley. The crank pulley will work but as others have said it isn't a bolt on affair.
              • geldartb
                The Situation
                • May 2004
                • 1994
                ive had the alternator pulley for awhile now and my charging system is fine.
                99 Grand Am GT
                • 92cavquest
                  • Feb 2008
                  • 150
                  MRZ told me that there was no bolt on pulley for a 2002 grand am (where my original motor came from) nor a 2005 Malibu.
                  • 1988GTU
                    LB62LHObbqftmfw
                    • Nov 2005
                    • 2475
                    http://s60.photobucket.com/albums/h5...t=DSC00852.jpg
                    Why do you have such thick spacers? I don't see a turbo or SC..
                    Change those hoses for non over sprayed ones!
                    • geldartb
                      The Situation
                      • May 2004
                      • 1994
                      welcome to the old pic club. it doesn't even look like that anymore.
                      99 Grand Am GT
                      • 1988GTU
                        LB62LHObbqftmfw
                        • Nov 2005
                        • 2475
                        Okay then, let me rephrase that for you.
                        Why did you have such thick spacers? I don't see a turbo or SC..
                        Sure hope you changed those hoses for non over sprayed ones, those look UGLY!
                        Better?
                        • RedBird
                          Aka Mr. 5th Motor
                          • Sep 2006
                          • 426
                          what's wrong with big spacers? long runners promote low-end torque, an extra inch would help a little, and also reduce heat-soak of the UIM/TB
                          Cammed 3400 --> 224whp 210wtq
                          Cammed 3500 --> ???
                          1 of 5 3500 J-Bodies
                          • geldartb
                            The Situation
                            • May 2004
                            • 1994
                            it definitely kept the UIM significantly cooler.
                            now ive got the 3500 UIM and 1/2" spacers i had on now.
                            99 Grand Am GT
                            • 1988GTU
                              LB62LHObbqftmfw
                              • Nov 2005
                              • 2475
                              How many "1/2" spacers do you have on there? Why not have an one piece thick spacer cut? It doesn't look great at all.
