Difference in 3400 and 3500 Camshaft Housing Bore?
  • sprucegagt
    Old School KI
    • May 2005
    • 703
    I've been checking out Dura-bond's new 2010 catalog and noticed what may be a problem. I was under the impression that 3400 and 3500 cam bearings were the same diameter. But appearently they're not.
    3400 Camshaft Housing Bore
    Position 1: 2.0100"
    Positions 2 & 3: 1.9995"
    Position 4: 2.0095"
    Position 1: 2.1766"
    Position 2 & 3: 2.1565"
    Position 4: 2.1766"
    Now where this may be a problem is if you wanted to use SBC cam bearings in your 3500.
    5.7L/350 Chevy Small Block Gen I
    Position 1: 2.0200"
    Position 2 & 5: 2.0100"
    Position 3 & 4: 2.0000"
    As you can see SBC bearings are ~0.14" undersized for the bore, thus they won't fit properly.
    Your local OBDII moderator
    2000 Grand Am GT w/ WOT parts
  • Weatheralls Auto
    Spinning out of control
    • Dec 2009
    • 536
    I have not checked myself, but are you sure you were looking at a Non VVT 3500?
    Just curious.
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
    • sprucegagt
      Old School KI
      • May 2005
      • 703
      Yes, verified against this site by VIN code. Dura-Bond doesn't go by RPO code.
      I also should note that the #1 position cam bearing is wider for 3500 than 3400.
      3400 Position 1 Cam Bearing Width: 0.625"
      3500 Position 1 Cam Bearing Width: 0.905"
      All other positions had the same width between 3400 and 3500.
        • 13520
        sounds like a VVT 3500 to me.
          Camshaft Bearing Bore Diameter-Front and Rear 2.009-2.011 in
          Camshaft Bearing Bore Diameter-Middle #2 and #3 1.999-2.001 in
          3500 LX9
          Camshaft Bearing Bore Diameter - Front and Rear 2.009-2.011 in
          Camshaft Bearing Bore Diameter - Middle #2, #3 1.999-2.001 in
          3900
          Camshaft Bearing Bore Diameter - Front and Rear 2.175-2.177 in
          Camshaft Bearing Bore Diameter - Middle #2, #3 2.155-2.157 in
          that's the info that's on this site... i can check my 3500 block tomorrow though.
          • sprucegagt
            Old School KI
            • May 2005
            • 703
            What's the VIN for a VVT 3500?
            • Weatheralls Auto
              • Dec 2009
              • 536
              I beleive in 07 it would be a Vin 1 LZ4 or LZE
              As of April 2
              Injectors: #36 GTPs
              TB: 65mm TCE
                • 9187
                I guess I could go measure mine... Will do after dinner.
                  • 9187
                  I just measured 2.010" on the the first hole.
                    that must have been a quick dinner...
                    • sprucegagt
                      Old School KI
                      • May 2005
                      • 703
                      <- Brad's dinner
                      I guess their catalog is wrong. But they do call out a 3.5 L VIN 8 with those characteristics. Oh well.
                        • 9187
                        I squeezed it in before dinner. I did knock over my 3500 crank trying to pull the engine out as well...
                          I sold a 3500 cam to someone to put in a 3400... never heard about any issues with it so I would assume this is wrong.
                          • sprucegagt
                            Old School KI
                            • May 2005
                            • 703
                            The cam isn't the issue, just cam bearings, or well they were.
                              Ok, wasn't sure if you were trying to say that the .14 difference also carried over to the cam or not.
