ARP Rod Bolts
  • eckoxl
    • Jul 2009
    • 230
    ARP Rod Bolts
    I have a set of APR Rod Bolts and went to have them pressed in and the shop said that the holes have to be enlarged in order to fit them. Is this true?
    1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
    • 13525
    No. Not the first time I have heard this nonsense though
    • eckoxl
      • Jul 2009
      • 230
      Whats the best way to get these in? What kind of press?
        • 13525
        Doesn't matter, just a press.
        • eckoxl
          • Jul 2009
          • 230
          Like this one?
          http://www.harborfreight.com/cpi/cta...emnumber=30999
          • blowns10
            • Feb 2010
            • 59
            I reallly doubt you need to actually enlarge the holes, according to ARP thay are designed as direct replacements for the original rod bolts. I have not used them but will use them when it's time for an overhaul!!. Late.
            I need a bigger engine!
            • eckoxl
              • Jul 2009
              • 230
              Cool. So I have a couple more questions
              1. Will that press work?
              2. Do I have to get them honed? Ive read that it messes the bore up.
              3. Basically how do I install them? lol
                • 13525
                That was a vice, not a press.
                Have what honed? Have a shop install them and if they say they don't fit, find a better shop install them.
                  This is a press:
                  http://www.harborfreight.com/cpi/cta...emnumber=33497
                  It's the same one I have too.
                  • 95Grand-Am
                    • 268
                    When you have the rod bolts changed you should have the rods resized, thats what the engine shops normaly recomend and thats what I have always had done.
                    • geldartb
                      The Situation
                      • May 2004
                      • 1994
                      This is a press:
                      i have the same press but the 6ton version. bought it at a swap meet for $25 so i cant really complain.
                      99 Grand Am GT
                      1357 cam 227 233 .050 dur
                      515 515 lift 112 lsa
                        • 13525
                        I have the rods cut and resized as well when I have ARP bolts installed.
                        • eckoxl
                          • Jul 2009
                          • 230
                          So when I drop them off, I should say I want the bolts installed and have the rods resized and cut? And what does it mean to cut them?
                          • blowns10
                            • Feb 2010
                            • 59
                            having the rods resized means to bring them back to within the OEM specs and as for having them cut....i don't really know the answer to that, maybe it means cutting them where the parts meet (the rod and the cap)? I've never heard the term "cut" in the machine shop?. Maybe someone can explain.
                            EXAMPLE:
                            A ( )----- B
                            In this illustration part A is the cap and part B is the connecting rod, and in the middle space, for illustration only, is where the two meet and the bolt holds the two together, maybe the part where they meet has to be "cut" because it may be warped and just needs to be true again (Straight, Flat)
                            Maybe I'm wrong but that's my 2 cents. Late.
                            • eckoxl
                              • Jul 2009
                              • 230
                              Thanks for all the info guys! They are at the shop as we speak!
