cam shaft swap help
    replied
    ive search for lsa and icl and got nothing.
    The computer is not going to autotune itself. It will skew fueling but that is not going to be a good way to go. If you have raw gas going through the cat and out the mufflers, there is a serious issue. Having it tuned or getting the vcm suite are the best options.
  • Rootie524
    replied
    yeah cam specs are earlier in this thread
    so your saying when ever i do any sort of mod like this or what you did i need to disconnect the battery and "reset" the PCM to have it learn the new mods. And when you say drive normally do you mean like i normally do (fast, quick accelerations) or like your supposed to (moderate acceleration, no racing, normal speeds) and by doing that it will better adjust my air/fuel mixture to something that works better?
    but it makes sense that im rich at idle because of the gas that comes out..and it makes sense that im lean at high RPMs because of the complete loss of power. I'm definitely going to get the 28lb injectors though..so Ben, PM me or something and let me know how much it will be for you to change my PCM for the new injectors.
    is there anything else i can do apart from getting a tune at a shop or getting VCM suite? or can you assure me it will learn the best it can and fix the sluggishness.
    replied
    hptuners would be the way to go to get it dialed in completely. I forget what cam specs you have now. Did you post those in this thread?
  • IsaacHayes
    replied
    The VE of the motor is totally changed, so it will run rich at idle and low RPM until the PCM tries to learn the differences, but it will never really "learn" just adjust as much as it can. It will run lean at higher RPM's where the power band has shifted... For a comparison my motor which does not have a cam change, but has large exhaust (no headers) and big port intakes, 3500 plenum and 65mm TB takes about 2 weeks of driving normally before MPG and power response is back to normal after disconnecting the battery.. If it was tuned it wouldn't be but a few hours if that.
  • Rootie524
    replied
    how do i get a tune? buy an HPtuner thing? because i need something. i just went driving today and first gear is amazing but 2nd gear acts like 3rd or 4th. its pathetic. it's slower than it was before.
    im going to list a whole bunch of things i noticed..try to help me figure this out.
    when i start the car sometimes out the tailpipe i see it spitting drops of liquid which i presume is gas. and it seems to be worse on gas (although expected..it seems worse than it should) so if im running rich, would that cause the complete loss of power im seeing? idk why i would be running rich..not a clue
    also, when i rev it alittle i hear a squeal in the engine. it's sounding like a vacuum leak but i have no idea where from. i thought at first the heads but i torqued those puppies down and did the extra 90 degree turn or whatever it was..so im thinking possibly LIM? and i know leaks cause power loss..
    and when i accelerate when its shifting gears it seems to pause for a second and slowly change gears. before it was super quick because i had my shift pressure adjusted in a PCM tune..so idk.
    my theory is new cam..bigger lift..more air coming in..needs more gas in the mixture. also bigger exhaust lift so more air going out..needs headers to make it leave efficiently.
    ill take a video when it stops raining of me driving so you can see the loss im talking about..and of the engine bay and the squeal. but i just want to thank you all for bearing with me and helping me out. i know i have a lot of problems and ask a lot of questions..but im learning so much and i thank you all.
  • IsaacHayes
    replied
    If it had the large port intakes, then the valves should be large too like the 3400 and your 2002 3100. So if that was the case the heads are close enough. If it had the smaller valves then it's an older casting and wont flow as well as the other head, but won't blow anything up just wont be optimal for power/etc.
    3500 valves are lighter. Lift is a function of your cam and rockers, not the valves. If the valves had more lift when open, then they would never seat all the way when closed... lol
    Yes a tune is proper way to do it when changing the VE of the motor significantly like with a cam.
    replied
    I can change the injector size, but I don't have anything tuned for that setup. I hope to get tunes figured out for my parts as I have access to the vehicles.
  • Rootie524
    replied
    ok good.
    next questions are:
    how do 3500 valves help? more lift and they are lighter? and will the increased lift cause it to knock pistons or its not that much of a lift?
    and do i need to tune anything PCM wise because of my new cam and supporting mods? my air/fuel ratio should still be good, right?
    and i plan to get 28lb injectors in the future..Ben, can you tune my PCM for them..or anyone else here?
    replied
    It can't be a 98 then. 99 was rare but available in large port for the 3100.
    replied
    If it had large port heads then you'll be fine.
  • Rootie524
    replied
    but if i have one 2002 3100 head with 2002 valves and one 199? 3100 head with 199? valves is that going to mess stuff up?!
    im guessing its a large port because i know small ports have the lines on the UIM..this one did not.
    replied
    99 3100 heads suck compared to 3400 heads. Smaller intake valve and worse casting.
  • Rootie524
    replied
    the car is running great. but i may have made a pretty big mistake...anyway, two exhaust manifold bolts broke off in my head..it was really bad and the bolt extractor kit i had wasnt working so i said F it and got a new head. it was only $35 with the valves and springs. since it already had good valves in it i left them in and just put my new stiffer valves springs on. this was a head off what seemed to be a 1998 or 99 3100 engine. i have a 2002 3100 engine. are the valves any different? the port size isnt..it's still a large port. but i saw somewhere the valves are different lengths and im wondering if that is going to F shit up for lack of better words. so i have one 2002 head with stock valves and one 199? head with stock valves..
    i may be putting those ported heads on sooner than i had anticipated.
  • IsaacHayes
    replied
    yes.
  • Rootie524
    replied
    i am aware of that and you can normally tell by the look of the UIM because it has lines on it. but i have a 2002 3100 in need of heads..i found a good car at the local junkyard to get heads off of. its a grand am with a 3400 in it. i have a large port, im guessing the 3400 is a large port as well despite what year it is. because i believe it might be a 1999. not sure..
    so would that match up then?
