G6, 3500, 3900
  • GPXSS
    • 588
    G6, 3500, 3900
    Pic of the 3900 thats supposed to be used in the G6:
    not sure if anyone has posted this yet or not
    I modify stuff
  • Rhedalert
    Dr. Feelgood
    • 1574
    That....is one long belt.
    Brian
    3400 SFI V6, 4T60e
    • phantom505
      • Jan 2004
      • 70
      To hell with the belt..... look at the UIM!
      And what is that tumor on the front bank? The manifold heat shield?
      It\'s ugly, and turbocharged!
      264 HP and 284 ft/lbs at the wheels(@9psi), power curve like none other!
      And the transaxle to get it to the ground!
        • 9191
        Here is a VERY bad cutaway view of it.
        I told you it was bad....
        • Anonymous
          Well the guy is in high detail, and to some of us that is a good thing.....
          That UIM is awful....
          • TurboSedan
            • Jun 2004
            • 218
            if it was a V8 the UIM would almost look like a limp....uh yeah nevermind
            '91 Cutlass Supreme sedan - 3.1 Intercooled Turbo / Getrag HM-282 5-speed - 13psi / lightly modded
            '98 Regal GS - 3800 Series II Supercharged/HM-4T65E-HD - 180* T-stat, otherwise stock
            GM W-body Forums
              • 13531
              Whatever gets the job done looks good to me. Id rather change the timing belt on my 3.4 than change the belt on that sucker :P
              • XLR8ING
                Too Stupid To Quit!
                • 268
                I wanna see more details on the manifold! Why they'd go with that kind of design??
                Franz
                1990 Z24-NA 3.1L
                14.72 @ 92.24 MPH
                14.89 @ 94.92 MPH
                The boost is coming....
                • ikessky
                  • 614
                  [quote="Aaron"]Well the guy is in high detail, and to some of us that is a good thing.....[quote]
                  So, does this confirm any questions anyone had about Aaron??? Just joking!
                  I don't mind the intake so much. I hope they start putting them in some cars fairly quickly so that they start showing up in junkyards and ebay! :P
                  • v6h.o.
                    • 1418
                    looks much like the old catera intake manifold.
                    by the looks of it is that a Camshaft Phaser on the front of the cover that sticks out?
                    looks like it to me.
                    Colin
                    • mfuller
                      Mr. Common Sense
                      • Nov 2003
                      • 374
                      This is what I have been told:
                      The upper intake maifold is an active manifold, switching between long and short runners to maximize power at any RPM.
                      Yes, that is a camshaft phaser.
                      The exhaust manifolds are so huge because GM saw fit to integrate a catalytic converter into the manifold. Quicker cat lightoff = better emissions.
                      Matt
                      • TurboZ24
                        • 299
                        Now the real question is how do you phase a single cam motor? Usually you change overlap as one way to increase higher rpm HP. I guess they could have some funky cam over cam setup so you rotate the outer shaft and inner shaft separately.
                        Curtis
                        91\' Turbo Z24
                        http://www.turboz24.com
                        • GPXSS
                          • 588
                          Usually they just use a servo to move the cam independantly of the gear.. either advancing or retarding cam timing.
                          What I want to know is, can you swap the dualstage intake (upper/lower) on an older motor, or do the heads come with? Either way.. I can see another hybrid swap coming on.
                          I modify stuff
                          • v6h.o.
                            • 1418
                            that lower looks somewhat similar,... well the small amount you can see under the near the valve covers looks similar..
                            yeah the camshaft is advanced and retarded depending to increase performance.
                            Colin
                            • TurboZ24
                              • 299
                              But unless somehow the intake and exhaust lobes are separated and can be moved independently, you can only advance/retard the cam timing for the whole cam.
                              Curtis
                              91\' Turbo Z24
