few questions about UIM and LIM swap
    • 13531
    You want to run heavy gauge wire from the starter to the trunk, where it will go to the battery. No adapters, just 1 solid line front to back. If you put a fuse here, its gotta be huge for the cranking amps. The ground can go to the trunk or run it back up to the front and ground it on the block. 0 gauge would be a good idea.
    • 95cutlassproject
      • Jul 2010
      • 61
      Sounds easy enough, thank you for all the help , so 0 gauge is heavy gauge wire right?.
      Researching phase for project ( screamer engine reseach, in the coming years)
        • 13531
        Yup. 8 gauge is used for small amp setups. 4 gauge for 500 watts or whatever. 0 is even bigger.
        • 95cutlassproject
          • Jul 2010
          • 61
          thank you so much. how do you recommend i secure the battery down?
            • 13531
            Get a battery box that will screw to the trunk. Most parts stores will have something. I highly recommend a sealed battery as well such as an Optima.
            • 95cutlassproject
              • Jul 2010
              • 61
              #21
              sweetness, thank you so much
              • fastback4
                • Feb 2009
                • 175
                #22
                Well respected..........LOL depends on whom you ask?
                Originally posted by 95cutlassproject View Post
                Thank you so very much, i was thinking of going to the route of the 3500 UIM, but after your advice (and i know enough to know that you are well respected and know what your talking abou) ill just grab the 3100 large port LIM and UIM, now i just got to get the brattey moved. Once again thank you so much
                • 95cutlassproject
                  • Jul 2010
                  • 61
                  #23
                  I dunno i respect him very much, he was nice with helping me about my newbie question plus the work he does for the forum makes him well respected in my book
                  • fastback4
                    • Feb 2009
                    • 175
                    #24
                    True that! A futile attempt at being funny ha-ha
