3400/3500
  • twistedretta
    • Jul 2007
    • 11
    ok i have no clue bout cams, im buildin a 3400/3500, things i want to do over winter,
    port an poish heads,uim,lim
    ill have the 65mm 3.5dohc tb
    headers from wot-tech
    street/stip cam from wot-tech
    ls6 yellow springs
    LS1 Valve Spring Seats
    ok now what injecters should i use? my dads a chevy small block person he has a 383 stroker
    and he thinks that the cam is to big for my motor an i might mot have anuf vaccum an it wouldnt run right, im also tryin to find a way to tune it like dhp tunner, or hp tuner. i really need help plz
    btw its goin into a 96 beretta z26 thanks
  • twistedretta
    • Jul 2007
    • 11
    anyone?
      • 13533
      street/strip isn't that big really. No problems there. Either the 28# @ 62psi injectors or L67 injectors (36# @ 55psi) would be fine with tuning. 96 is only DHP tunable. I would use a 97 PCM though.
