Breather system and oil consumption
  • Azrael
    Accelerating uphill in OD
    • Apr 2005
    • 763
    I plan on giving the TB a good look over the weekend. It's an old 62mm FDP TB which I've had problems with the throttle stop screw coming loose before. Thanks for the numbers.
    1995 Grand Am SE
      there were a few of the setups in the links i found that used pumps.
      Oh yes a vac pump is ideal, but I would think that's much more involved, and is also bumping it to the next level of pulling a high vac on your crankcase, vs just evacuating it of contaminates and crap... it then uses power, or a belt to work. This way your not tasking your alternator, or an acc belt, its just pulling from the exhaust flow.
      I look at those things more like a poor mans vac pump, it doesn't pull so much to where the power increase is greatly noticed, but it will pull something and get the crap out, and not suck it right back into the intake.
      • geldartb
        The Situation
        • May 2004
        • 1994
        figure even with 2 of either of the kits you posted your only up to $40ish and down the road you could add a pump if you want. if i get around to it this year i may give it a try, or there is always next year. already got a few extra sets of valve covers to screw around with.
        one of those links from the google search said something about a pump from a cadilac.
        99 Grand Am GT
        1357 cam 227 233 .050 dur
        515 515 lift 112 lsa
        • AaronGTR
          boost lover
          • Jan 2004
          • 708
          I've noticed some issues like this myself on my car. Hard starts and sometimes a puff of white smoke out the exhaust when the engine is cold, but goes away almost immediately. Get some weird stumbles and surges at idle though until the car is warmed up. Both my NB and WB O2 sensors seem to be getting fouled fast though, possibly a combination of higher than stock WOT AFR's and burning some oil? I was down about 1/4 of a quart the other day, almost exactly 1000 miles since my last oil change.
          I actually have a catch can in my PCV line, but it never seems to have any oil in it so I don't think it's working. It was a cheapo can from NRG and didn't have any divider or filter material inside like they are supposed to have. I tried adding a small breather filter inside the can on the suction outlet, the theory being that it might slow down the air flow a bit and knock the oil out of suspension in the air, but it doesn't seem to be working. I was thinking of trying a different brand catch can, or maybe trying an air/oil/water filter like they used to dry compressed air and see what that does. I'd rather drain that occasionally than have to add another system to the car or keep burning oil.
          of course, I'm not 100% sure that's where the oil consumption is coming from though. Could also be valve seals or guides wearing out maybe? Or piston rings? Not sure. My other car is down getting the A/C fixed right now, but as soon as it's back on the road I'm planning on putting the grand am in the garage and doing some work on it. Going to check the plugs, do a compression/leak down test, etc.... never done that on this car so I'm curious what shape the rings are in.
          '97 Grand Prix GT 3800 (sold)
          Gotta love boost!
          • prophiseer
            Blaspheming Heretic
            • Jun 2006
            • 354
            After researching some prices . . . my cheap self decided it'd be more cost effective to make one. So, I've gathered my materials, and now have a project for this weekend. I'll prob take pics along the way and post them.
            On a related note - out of curiosity, I threw a vacuum gauge on the motor earlier this week just to see how hard it's pulling . . . warmed up and at idle, the motor is puling 28 in. Damn! So that probably explains the occasional stumble right off of idle, and the slight surging when cruising at lower RPM speeds (i.e. 25-45 MPH @ ~1500RPM) - engine vacuum is right at the MAP's maximum range. Anyone know of a GM 3-wire MAP that's capable of registering above 30 in of vacuum?
            N-body enthusiast:
            {'87 Grand Am SE - 3.0 90* v6} / {'93 Grand Am LE - 3.3 90* v6}
            {'98 Grand Am SE - 2.4 Q4} / {'99 Grand Am GT1 - 3400 60* v6}
            Current Project:
            {'90 Chevrolet C1500 Sport 350TBI}
              • 13525
              #21
              28" at idle is a lot. I didn't think that was even possible.
              • geldartb
                The Situation
                • May 2004
                • 1994
                #22
                that's kind of what i was thinking. i think with the stock engine mine hung around 17-20 although it's been awhile since it was stock.
                99 Grand Am GT
                • prophiseer
                  Blaspheming Heretic
                  • Jun 2006
                  • 354
                  #23
                  Well, like I mentioned in the OP - this motor isn't stock . . . and I have a tendancy to build a tight motor . . .
                  . . . but 28" shocked me a little bit as well. I would've figured no more than 22" or 24" . . . as it stands, I'm surprised the MAP hasn't kicked a code.
                  N-body enthusiast:
                  Current Project:
                  • Skeith
                    • Apr 2010
                    • 51
                    #24
                    What about a small cylinder in line with the breather tube alligned verticaly with a screen mesh to collect oil dropletts. this would reduce or prevent the oil from being pulled into the intake. It would theoretically act as an oil seperator and allow the oil to be pulled back into the rocker cap by gravity or negative pressure when the PCV draws the crank case emmisions.
                    this is just theoretical of course works in smaller scale and even higher pressures such as refridgeration systems to seperate the compressor oil from the refridgerant. Hell maybe going to a wreaker and snagging an oil seperator off an old AC system cleaning it out and retrofitting it would work.
                    Not sure how much vacuum we're talking about here, but it may work.
                    EDIT: whoops, i see now your pulling 28 inches, thats a bit high. (for some reson the forum wouldent let me see page 3 untill i posted, thought it was some sort of a glitch :shrug
                    damn, and im having trouble getting my engine to pull 16 inches, slowly ironing things out.
                    I see a small puddle of oil at the base of my TB and thought it was normal as well, even research on the PCV system online stated that it was a common occurance and one of the reasons the TB and plenium get so gummed up. But i guess the question is how much is too much?
                    • prophiseer
                      Blaspheming Heretic
                      • Jun 2006
                      • 354
                      #25
                      Well, some amount of oil is not only normal, it's inevitable. The breather line itself will also pull a very small amount . . . much less than the PCV system, though, as the breather is operating more on a venturi effect than on vacuum.
                      The more vacuum a motor is pulling though, the greater the quantity of oil that will be pulled through the vacuum system. Even more-so if everything is nice and clean, too (no gummy carbon buildup to absorb any amounts of oil).
                      TBH, considering the effects the oil residue has on the intake system - I'm really surprised manufacturers haven't started coming up with some kind of seperator system for the vehicles from the factory. Especially with the slew of drive-by-wire vehicles, and how detrimental that oil buildup is to the TB and the electronic motors that operate it. I can't count the number of GM and Ford DBW setups that have come in cause than ran like crap, and simply cleaning the TB and reseting the KAM gets everything back to normal.
                      N-body enthusiast:
                      Current Project:
