Which head gasket>>3100/3400?
  • fastback4
    • Feb 2009
    • 175
    On a 97 3100 block using 2000+ 3400 heads, which head gasket should be used.
    3100 or 3400 head gaskets....Regards.....Tom
    • 9190
    3100. You want to be close to the cyl. bore size. If you are really concerned about it, get a 00+ 3100 HG, since the 00+ 3100s and 3400 heads are the same. With that said, it's probably the same gasket (between the earlier 3100 and 00+ 3100).
      • 13525
      The 3100 head gasket has a 3.62 bore. The 3400 head gasket has a 3.75 bore. You choose based on the block, not the heads. The heads have the same size combustion chambers between 3100 and 3400 engines.
