basically at low engine speeds the plate is closed, forcing all the exhaust gas through the single, smaller opening, basically changing the turbo into a small turbine A/R, which spools the turbo very quickly, then as the engine speed increases the valve opens, allowing it to act like a large A/R housing, allowing for more flow and power than a smaller housing would.
Turbine housing sizing + quickspool valve
(You beat me to the punch.) Yep...Thats the theory.Originally posted by RedBird View Postbasically at low engine speeds the plate is closed, forcing all the exhaust gas through the single, smaller opening, basically changing the turbo into a small turbine A/R, which spools the turbo very quickly, then as the engine speed increases the valve opens, allowing it to act like a large A/R housing, allowing for more flow and power than a smaller housing would.
The real benifit of the "quick-spool" valve is being able to use an overall larger exhaust housing which would reduce breathing effort and free up hp.
However, Im changing my approach and using a fairly large exhaust housing in combination with a "divided pulse" style set of turbo headers with dual wastegates. The "divided pulse" system is ultimately more efficient and should provide better boost control. I just wont be able to run nearly as large an exhaust housing as I would with a "QS"-valve and non-divided turbo headers.Last edited by Driver_10; 11-27-2010, 01:21 PM.Took a break from working on the car. Got some better tools, got a better shop, got a better job... Its time to burn metal!
Heres a good pic that shows kinda how I intend to run the two wastegates on the "divided pulse" primary set-up...
This is not my pic BTW... but you get the picture
Last edited by Driver_10; 11-27-2010, 03:19 PM.Took a break from working on the car. Got some better tools, got a better shop, got a better job... Its time to burn metal!
For the record on my .63 AR T3 turbine with the 60-1 compressor it spooled off idle. It was full boost 1/2 throttle accross an intersection.
I have a 3 spd. automatic TH350 though. 4500 stall.11.92 @ 122 MPH 3400 91 Cavalier Z24 Intercooled S/C. -totalled-
My .69 A.R t3 non-divided "S256" was about the same way. It did very well on my old 3400 swap and had a torque band like an SBC.Originally posted by Mars View PostFor the record on my .63 AR T3 turbine with the 60-1 compressor it spooled off idle. It was full boost 1/2 throttle accross an intersection.
However, a moderately sized housing is restrictive at high rpms. To free up some power at higher rpms requires a larger turbine housing.
The challenge is to create an efficient system with usable low-end torque and good, flat, "mid to top range" power band. The parrasitic losses should as reduced as posible.
(Its a difficult goal, but not an impossible one)Took a break from working on the car. Got some better tools, got a better shop, got a better job... Its time to burn metal!
