3400
  • BadGrandPrixSE
    • May 2004
    • 47
    i have a 95 3100. I was wanting to put the 3400 heads on. I was wanting to know what else i would need for this to work.
    Thanks William
    1BadPrix
  • ikessky
    • 614
    Hopefully you are also going to use the lower and upper intakes and the TB from the 3400 as well. You will need to switch to the new style temp sensor (a 3 wire sensor in the t-stat housing) and you will need to address the difference in the EGR valve. It's easy enough to make an adapter plate for this. Someone else will probably say I'm missing something, but I'll let them add it!
    • blackbombshell95
      Kaiō-ken X 10
      • Jun 2004
      • 1386
      hello, i'm new, i'm a common over at clubgp.com........i also have a 3100 in a 95 grand prix, so the UPPER and LOWER intake, throttlebody, and heads from a 3400 can be swapped into a 3100??? what year grand am 3400 engines can be donors?????? and i'm guessing that i can have all ported and polished before i drop them in???
      so other modifications that can go along with it are a switch to a new style temp sensor, and a differencece in the egr valve. anything else. thanks for your info ikessky. know of anyone on this forum who has done this swap?
      02 GTP - 90* > Failboat
      www.blackbombshell95.com
      • ikessky
        • 614
        Brad (bszopi) swapped the intakes with the stock 3100 heads, but that was a while ago. There are some problems that can be run into if you use the stock 3100 heads with the new intakes. I'm sure there were other people, but I can't recall them right now. It's been a long day.
        GA's aren't the only vehicle that came with a 3400, so don't limit your search there. And yes, if you were planning on a port and polish job, it would be easiest to do it now before you put everything on.
        • BadGrandPrixSE
          • May 2004
          • 47
          Ok i ws needing to know some info and what to do because i am looking into buying some stuff for my motor. Hopefuly i can do a 3400 top end swap and not be to difficult.
          1BadPrix
          • blackbombshell95
            Kaiō-ken X 10
            • Jun 2004
            • 1386
            so its best to put the heads in also. so what cars have a 3400 that will work just fine in my 95 grand prix 3100??? any and all 3400s?????? i'm looking for specific years and makes and models if any know of any..... once again you are most helpful ikessky.
            • ikessky
              • 614
              I don't know when the GA's started getting 3400's. I'm thinking '98-'99. Any and all 3400's will work though. They came in Impala's, Venture's, Montana's, Aztek's, Alero's........... There is quite a long list to choose from. I would look for newer parts if you can find them, but even the '99 stuff will work just fine.
              Yes, if you are swapping the top end, I would do the heads also. You will eliminate any potential interference that the '95 rocker arms will cause and you will gain a better flowing head that has stock roller rockers.
                • 9190
                The minivans were the first to get the 3400s in 97. The cars (GA, Alero, etc) started getting them in 99. All 3100s from 2000-present use the same exact parts as the 3400s.
                Here is a link to the write-up between the different manifolds and the complications that may arise when trying to use the old style heads with the newer manifolds: http://www.60degreev6.com/index.php?p=pages&pid=68
                The EGR is the biggest issue, but as was stated, there are several people around here now making adapter plates for them since this is becoming a popular swap.
                • v6h.o.
                  • 1418
                  the Lumina vans also recieved the 3400 as an option in 96 those equiped with the 3400 had "venture" sticker packages..
                  Colin
                  • BadGrandPrixSE
                    • May 2004
                    • 47
                    I hope to do this swap next month.
                    William
                    1BadPrix
                    • blackbombshell95
                      Kaiō-ken X 10
                      • Jun 2004
                      • 1386
                      i hope to start the swap next week. who can i talk to about buying an adapter plate. i will buy it tomorrow on ebay..... anybody help set me up..... also th anks again for the information........ so some 3400 cars have more horsepower than other 3400 engines??? or is it all with the chip...... so would a 3400 out of a new grand am be the most recommended to use for a swap into my 95 3100??
                        • 13525
                        They are all the same performance wise as far as the manifolds and heads go. The only change is the coolant pipe connection and the EGR mounting point.
                        • BadGrandPrixSE
                          • May 2004
                          • 47
                          Does anyone have any pics of this done before. I mean the 3100/3400 swap the efr mount point and coolant connection
                          William
                          1BadPrix
                            • 9190
                            The link from above (http://www.60degreev6.com/index.php?p=pages&pid=68) showed the coolant connection. I have pics of the EGR somewhere...
                            • blackbombshell95
                              Kaiō-ken X 10
                              • Jun 2004
                              • 1386
                              so i will need new intake gaskets too then huh..... and a new headgasket for the 3400 when i do the swap on my 3100??????
                              does anyone know who can make me an adapter plate???? i will pay???
                              also for the throttlebody, i can start there first, instead of getting a 3400 throttle body polished, would it be better if i get the fdp throttle body?? what would work the best????
                              also for the coolant heater hose, do i buy a factory hose??? or do i just buy heaterhose from a local parts store and make it fit???
                              man i can't wait to post pics soon.
