Gasket Matched Intake Manifold and Throttle Body
  • trewyn15
    • Oct 2010
    • 178
    If i get just a gasket matched intake manifold and throttle body but do nothing to the LIM manifold will it negatively affect anything or will i gain anything?
    2004 Monte Carlo LS
    Build Thread
    Youtube Channel
    ^Add and Sub & I'll Return The Favor^
    • 9189
    I doubt it will negatively affect anything, but you aren't going to gain anything. If money is an issue, I would probably go with ported upper and lower intake, and wait to get the TB later.
    • trewyn15
      • Oct 2010
      • 178
      theyre together, if i went with a ported lower later would the upper then benefit also?
      basically what i would be getting is a gasket matched and polished intake manifold and throttle body for a 3400, i realized that gasket matching will give some benefit, but will there be benefit without the lower intake manifold, and would that gasket matched items benefit anything say, if i already had a ported lower?
      hope that makes sense lol
      2004 Monte Carlo LS
      Build Thread
      Youtube Channel
      • bob442
        Show Me Your KITS!
        • Nov 2008
        • 1305
        Like Brad said, get the ported upper and lower, and the Tb after if money is the issue. If not, only getting a larger Tb will benifit till you get the lower ported to match an upper ported intake.
        Having just a ported lower might not yeild as much of a gain than having both either.
        Also, taking the lower intake off while the upper is removed is less work than taking just the upper intake off in most applications, so if your there, you maise well do both, and its always a good idea to replace the lower intake manifold gaskets with felpro steels.
        Bob
          • 13522
          Felpro isn't the only company that makes the metal gaskets. You will benefit from a ported (don't polish) upper intake on a stock lower. Porting the lower would be better but if you don't want to pull it then its not going to hurt, or even leave you with nothing gained.
          Gasket matching is one method of porting. It isn't necessarily the best way to port but its by far the easiest to understand, and abused as a generic term for all of porting. I just wanted to point that out.
          • trewyn15
            • Oct 2010
            • 178
            thanks ben, i havent posted a ton but everything i have posted you have helped a ton with, i have a nice gasket matched intake manifold lined up that is also polished for a great price, but i wouldnt do the LIM right away, which LIM that you carry would be similar to a gasket matched UIM or would you need pics to justify that?
            2004 Monte Carlo LS
            Build Thread
            Youtube Channel
              • 13522
              If its gasket matched for the 3400 gasket, then the sportsman and competition 3400 lower will work just fine.
                Live life 3.7mi at a time
                • 4555
                I saw gains with stock heads, stock LIM and ported upper; more gains with stock heads, ported lower/upper; most gains with everything matched on the flow bench. You would think that the step would make things worse, but as Ben mentioned not all the gains will be had where parts meet at the gasket. Hence the general thinking that "gasket matching" is porting, when in reality, research may not say so.
                To answer you question bluntly, if you want to dig in the engine a little at a time, making the parts better as you go will benefit in efficiency, power and reliability. Preventative maintenance never hurts, using upgraded replacement parts is even better.
                • trewyn15
                  • Oct 2010
                  • 178
                  so your saying that getting what im looking at would be a good idea?
                  and either of those would be fine with the gasket matched?
                  2004 Monte Carlo LS
                  Build Thread
                  Youtube Channel
                    • 13522
                    Yes to both those questions.
                    • trewyn15
                      • Oct 2010
                      • 178
                      alright cool, thanks for the help, i just posted in the members rides section if you want to see what this work is going to be done to.
                      im looking at doing the UIM first and then finding someone to help me with the LIM when the time comes because that task is a little bigger obviously, thanks for the help
                      2004 Monte Carlo LS
                      Build Thread
                      Youtube Channel
                      • trewyn15
                        • Oct 2010
                        • 178
                        also, the one that i'm looking at has the EGR delete, will that give me anything or take away from anything?
                        2004 Monte Carlo LS
                        Build Thread
                        Youtube Channel
                        • Azrael
                          Accelerating uphill in OD
                          • Apr 2005
                          • 763
                          The EGR is an emissions system. It allows a metered amount of exhaust gas into the intake at highway speeds. The only gain in removing it is helping to keep the intakes clean.
                          1995 Grand Am SE
                            • 13522
                            EGR delete is fine. Just make sure you have the computer programmed for no EGR.
                            • trewyn15
                              • Oct 2010
                              • 178
                              if i dont have the computer programmed for it will i have trouble with just codes or more? if i just have a code i'm fine with it for a while, but i don't want to run lean or something like that
                              2004 Monte Carlo LS
                              Build Thread
                              Youtube Channel
