3100 Cam Question
  • bluebomber
    • May 2004
    • 23
    3100 Cam Question
    I just need a quick answer before the shop grinds my cam. 1994 3100 has a hydraulic roller camshaft and only the pre 94 3.1s had flat-tappet correct? Thanks in advance!
    1994 Grand Prix SE 4dr - Brilliant Blue Metallic
    Magnaflow Hi-Flow (And Bashed) Cat
    2.5\" Split Dual Exhaust
    Two Flowmaster 40 \"American Thunder\" Mufflers
    7\" Cone Cold Air Intake
    FFP Poly Motor Mounts
    16.320 @ 83 MPH w/ 2.296 60\'
  • Guest
    YES
      • 9191
      Well... there still were some flat-tappet 3.1Ls in 94. But, ONLY the 3.1MPFIs, not the 3100SFIs. If its a hollow core cam, then its a hyraulic roller...
      • bluebomber
        • May 2004
        • 23
        Thanks for the quick response. Any things I should be ready or aware of before we begin the cam swap?
        For example, what should I expect to have to take off? What are some common bumps in the road? What extra parts should I have on hand?
