i gotta figure out this stalling issue, it logs p0101 that is mass air flow performance, all i have done is glorified the PCV system witha canister, it all routes the same, and uses the factory valve, and blocked off the egr entirly and eliminated its mounting, leaving it dangling in the engine bay for now plugged into the harness, if i clear the code and start it it will run for 10-40 seconds and shut down, with a neer impossible start unless i hold the throttle wide open. its sure quiet and sounds healthy though
And guys tell me, did i reach my goal of sounding like the fiero????!!!!
3400 N/A Monte Build Thread
That sounds ridiculously awesome!Originally posted by bob442 View Post
Very unique!
well, you guys tell me....
i will note that i have a exhaust leak present, this is a 2.5" exhaust, magnaflow cat, 18" long flowpro resinator. and of course waste spark headers...i could only get it up to 4000rpm and it cuts out.
ENJOY!!!
I look forward to hearing these headers. Definately a unique Monte now.
well i got all my new down pipe parts, and my crank case canister all sorted out, so its going to get broken in tomorrow!
I bet you were dreaming of a time once long ago, when the weather was nice.
it started to snow while i was working on it! it all fell at once! lol
Whats with all the snow on this setup... Cover the pig up when your not working on it!!!
I have all the tap's I need in many sizes both metric and standard. Canister I'll make or buy somewhere, I was just commenting. Your pics inspired me to do the same for my build.Originally posted by bob442 View PostPipe taps are expensive or hard to *borrow* I will warn you in advance. If you want a canister I can have one made if a few people are in. Other wise its not worth wasting my or anyone else's time
I installed a check valve to keep boost out of the crankcase and routed the rear feed to a tap between the compressor and air filter. So hopefully when the airflow increase in boost, the venturi effect will kick in and provide a slight vacuum in the crankcase.
But with the swapping of my CXRacing Turbo for a Ball Bearing Turbonetics, I don't want to be adding any oily vapor into the compressor like that.
So I think I need to go the route you took. All I need is a catch can, I have the -6AN adapters and the hoses. Plus the tools, a nice tap & die set.Last edited by TGP37; 01-17-2012, 09:12 AM.
Not going to lie, I am honestly thinking about sending you a set of valve covers to get set up.
it threads into the back valve cover, i tapped and plugged the intake...
the catch can is mounted for now with a make shift screw clamp modified and rivited to the motor mount you see closest to it.
thanks for the interest though, guess you seen the FS add.
It is cold as shit today how ever sunday peaked at -3 and dropped to -6, i was at it till 9:30, after mixing vodka and AMP nearly killed me, i called it quits and job well done.Last edited by bob442; 01-16-2012, 11:37 PM.
Looks very nice.
So this replaces the PCV in the front valve cover, eh?
How did you mount the catch can?
Does the 90 degree fitting thread into the UIM then? I can't tell from the picture.
