3400 N/A Monte Build Thread
  • bob442
    Show Me Your KITS!
    • Nov 2008
    • 1305
    #106
    well this is my current progress, i should have it running by sunday evening with a full exhaust clip for EVERYONE!!!!
    • robert 1980
      • Aug 2009
      • 302
      #107
      Looks good bob glad to see your almost finished.Im sure it's cold as shit up there.Can't wait to see the clip=)
      G/L
      • mfuller
        Mr. Common Sense
        • Nov 2003
        • 374
        #108
        Looks very nice.
        So this replaces the PCV in the front valve cover, eh?
        How did you mount the catch can?
        Does the 90 degree fitting thread into the UIM then? I can't tell from the picture.
        Matt
        • bob442
          Show Me Your KITS!
          • Nov 2008
          • 1305
          #109
          it threads into the back valve cover, i tapped and plugged the intake...
          the catch can is mounted for now with a make shift screw clamp modified and rivited to the motor mount you see closest to it.
          thanks for the interest though, guess you seen the FS add.
          It is cold as shit today how ever sunday peaked at -3 and dropped to -6, i was at it till 9:30, after mixing vodka and AMP nearly killed me, i called it quits and job well done.
          • 95cutlassproject
            • Jul 2010
            • 61
            #110
            Not going to lie, I am honestly thinking about sending you a set of valve covers to get set up.
            Researching phase for project ( screamer engine reseach, in the coming years)
            • TGP37
              Shadetree Engineer
              • Jul 2011
              • 1027
              #111
              I installed a check valve to keep boost out of the crankcase and routed the rear feed to a tap between the compressor and air filter. So hopefully when the airflow increase in boost, the venturi effect will kick in and provide a slight vacuum in the crankcase.
              But with the swapping of my CXRacing Turbo for a Ball Bearing Turbonetics, I don't want to be adding any oily vapor into the compressor like that.
              So I think I need to go the route you took. All I need is a catch can, I have the -6AN adapters and the hoses. Plus the tools, a nice tap & die set.
              • bob442
                Show Me Your KITS!
                • Nov 2008
                • 1305
                #112
                Pipe taps are expensive or hard to *borrow* I will warn you in advance. If you want a canister I can have one made if a few people are in. Other wise its not worth wasting my or anyone else's time
                • TGP37
                  Shadetree Engineer
                  • Jul 2011
                  • 1027
                  #113
                  I have all the tap's I need in many sizes both metric and standard. Canister I'll make or buy somewhere, I was just commenting. Your pics inspired me to do the same for my build.
                    Whats with all the snow on this setup... Cover the pig up when your not working on it!!!
                    • bob442
                      Show Me Your KITS!
                      • Nov 2008
                      • 1305
                      #115
                      it started to snow while i was working on it! it all fell at once! lol
                      • TGP37
                        Shadetree Engineer
                        • Jul 2011
                        • 1027
                        #116
                        I bet you were dreaming of a time once long ago, when the weather was nice.
                        • bob442
                          Show Me Your KITS!
                          • Nov 2008
                          • 1305
                          #117
                          well i got all my new down pipe parts, and my crank case canister all sorted out, so its going to get broken in tomorrow!
                          • TGP37
                            Shadetree Engineer
                            • Jul 2011
                            • 1027
                            #118
                            I look forward to hearing these headers. Definately a unique Monte now.
                            • bob442
                              Show Me Your KITS!
                              • Nov 2008
                              • 1305
                              #119
                              well, you guys tell me....
                              i will note that i have a exhaust leak present, this is a 2.5" exhaust, magnaflow cat, 18" long flowpro resinator. and of course waste spark headers...i could only get it up to 4000rpm and it cuts out.
                              ENJOY!!!
                              • Fireball
                                • Sep 2010
                                • 128
                                #120
                                i will note that i have a exhaust leak present, this is a 2.5" exhaust, magnaflow exhaust, 18" long flowpro resinator. and of course waste spark headers...i could only get it up to 4000rpm and it cuts out.
                                ENJOY!!!
                                That sounds ridiculously awesome!
                                Very unique!
