3400 lower on 3500 heads?
  • 85maro
    • Sep 2006
    • 140
    I've been told the two can't be used together but I don't see why. I have a 3500 & 3400 lower side by side and after a few measurements I don't see any reason for it not to work. The only difference I can see is the little notch at the mouth of the 3500 lower. Enlighten me?
    • 13522
    bolt them together.
    • mickaz
      • Aug 2004
      • 350
      bolt them together.
      that must be the best reply ever...hmm maybe you should pin this reply LOL
      Mike 60degree addict.
        • 13522
        The problem becomes very obvious when you bolt them together. They raised the ports on the 3500s:P
        • 85maro
          • Sep 2006
          • 140
          I don't have the heads yet, I only have the manifolds to compare. That's why I asked.
            like Ben said, there is a big difference in the orientation and shape of the ports. Not going to work at all.
            • 85maro
              • Sep 2006
              • 140
              Alright, thanks. So even if I smear a bunch of jb weld on it I can't make it work? JK.
                JB weld won't work.. but Mighty Putty would.
                • TechRod
                  Destruction Worker
                  • Feb 2009
                  • 162
                  And this whole time I've been using cheetah blood?
                  "It's your car. Do with it what you wish, but as you enter this unknown world you will need to invent the wheel all over again. For the adventurous and those that are backyard mechanics who have nothing but time you might like this. Most have plenty of frustrating moments and the process usually takes significantly longer then what anyone could imagine. The end result of this conversion is completely up to you." - Jon McCullough of BMCautos.com
