LS1 Lifter springs
  • jschmieding
    • May 2009
    • 44
    LS1 Lifter springs
    Do you really need to swap out the check ball spring also or can I just swap out the piston spring and still be ok? Thanks.
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    are 60* lifters different from SBC lifters? I though they were all the same externally?
      the OD is but the internals are different than flat tappet lifters.
      OP, why not swap out the check ball springs?.. it takes 30 sec per lifter once the main plunger is out.
        • 13534
        The TCE/LS1/LT4 lifter springs are stiffer than the regular 60V6 or SBC lifter springs. You will need to do both springs. Use a pick to get the cup out of the bottom.
