Originally posted by SappySE107
View Post
Starting my engine build.
Well if you can get away with .040" quench on a 4"~4.3" piston then .030" quench on a 3.7" piston is not unreasonable. The reason you need a safety margin is for a bit of rod stretch and the piston rocking in the bore. And the smaller a piston is the less these variables will be a problem.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
That's a nice looking 'bird, good luck with the build
Thanks!
I haven't purchased any parts yet, Im saving paychecks so I can buy everything in the bottom end at once.1988 Firebird
3.4 60*V6
9 Bolt Rear, 3.27:1, Disk brakes
Edelbrock 3790 Cam & Lifters
COMP Cams Magnum Steel Roller Tip Rocker Arms 1414-12
COMP Cams High Energy Pushrods 7816-12
COMP Cams Valve Springs 980-12
PaceSetter Headers 70-1206
