high compression 3400 build
  • stewartfn18
    • Aug 2008
    • 114
    so,for those who dont know this isnt my first rodeo. my mods list includes:
    old 1393(stage 2) cam
    3500 heads
    comp 986's
    ls lifter springs
    s&s
    cai
    65mm tb
    2.5 custom header back
    comp ported manifolds
    tune
    28 lb injectors
    tce afpr
    to add to the madness ive ordered:
    dohc pistons
    head studs
    stock conrods
    cometic 3400 head gaskets, compressed thickness of .075 to yield 11.6:1. more parts are to be ordered.
    probably p series rod bearing
    pre 00 timing set.
    new crank cuz the snout on mine is stripped
    maybe arp rod bolts
    maybe arp main studs
    i need advice on the last two.
    MODS: DS CAI, TCE 65 mm tb, TCE AFPR, TCE LS lifter springs, WOT ported UIM and LIM, 3500 heads, comp cams valve springs locks and retainers, 1393 grind cam, S&S headers, custom 2.5 in catback, flowmaster 80 series , no rez, and to top it all off, an MPR tune. Among misc gauges and appearence things
    • 13533
    Don't need the main studs, but I would use the rod bolts.
    • stewartfn18
      • Aug 2008
      • 114
      ordered my gaskets last night. i read that itll take 2 weeks to be shipped. do they get shipped to me from cometic or do they get shipped to you and then you ship them out
        Hello high octane fuel... LOL good luck with the build.
          • 13533
          The cometic gaskets get shipped to me first though I could see if they will drop ship without an extra fee. Other than the cam, the compression does work with 93 octane.
          • stewartfn18
            • Aug 2008
            • 114
            parts came in
            and what do you mean "other than the cam"
              • 13533
              260 adv duration is not much for 11.6:1.
              • stewartfn18
                • Aug 2008
                • 114
                what will not having enough duration do? noob question
                • Blacktree
                  '87 Fiero SE
                  • Dec 2006
                  • 48
                  With high static compression, and a camshaft with short duration & low overlap, your engine will be like a diesel... lots of low-end torque, but won't like to rev. Plus, the mild cam will yield a higher dynamic compression ratio than a more aggressive cam, which will put more stress on the rod&main bearings. Plus, it'll probably ping... even on 93 octane.
                  A more aggressive camshaft will reduce dynamic compression, which will reduce the tendency to ping, and allow the engine to rev higher (i.e. more power). For ~11:1 compression ratio, you should be looking for around 225-240 degrees duration @ 0.050" lift. (I used duration @ 0.050" lift, because advertised duration can vary from one mfgr to the next)
                    • 13533
                    The tune will have to be perfect and even that might still have an issue with detonation. The cam is meant to trap as much as possible, with -18.9 overlap at .050 and 42.6 seat to seat. With higher compression you want to bleed off some of the charge at lower RPM to keep the same power or increase it slightly, while enjoying the full benefit at higher RPMs that the lower compression wouldn't allow to carry so well without costing a huge hit to bottom end power.
                    • stewartfn18
                      • Aug 2008
                      • 114
                      question then, can you grind a cam with the same lift but a longer duration so that i can keep my pushrods and not have to get new ones?
                      • stewartfn18
                        • Aug 2008
                        • 114
                        i mean really the duration is not THAT far off
                        • trotterlg
                          • Feb 2011
                          • 326
                          It will be interesting to see how these things run. Below are the cam specs on the cam I have in my 3.1 12.4 to one build, and I am told it may be too hot. Guess this is all black magic, or that cam selection is not a very understood process. Larry
                            • 13533
                            Cam selection isn't black magic. Your cam is no where close to hot enough for your compression. Are you running it right now?
                            • Blacktree
                              '87 Fiero SE
                              • Dec 2006
                              • 48
                              Yeah, those cam specs are pretty mild. At least, the lift and duration are pretty mild. But what's up with the LSA? It looks like that camshaft was designed to maximize cylinder pressure (i.e. for an engine with a low compression ratio). With a 12.4:1 SCR and that camshaft, your rod bearings are going to take a beating. The engine will also be prone to detonation.
