fiero 3500 swap...
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    fiero 3500 swap...
    I'm doing a 3500 (LX9) swap into my 85 fiero, I already have a 7730, and I know I need a crank trigger and a throttle body, is there a TB I can get at a junkyard that will bolt to the 3500 upper? I also need a new timing cover (mine was damaged in shipping) do I have to use one off of a 3500, or can I snatch one off of a 3400? what size injectors should I run since my fuel pressure will not be 65 psi like the late model cars?
    Thanks-
    Eric.
    • 9191
    You can use a TB of a 3.5L Intrigue, but then you need an adapter for it to work. I'm not aware of any other TBs that will bolt up, besides the billet ones from WOT. Any 3x00 timing cover will work on the 3500. I'm not 100% on the fuel injectors, but I would think anything in the 19-24lb range should work.
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      Thanks, that makes getting a cover a little easier, my local yard if full of 3400's! I've heard I will need an alternator from an earlier model than the 3500 is, is there a specific one I should look for?
      • hookdonspeed
        • Jun 2007
        • 322
        i have a 00+ 3100 and a 3500 timing cover for sale, make me an offer...
        see my 3500 fiero swap thread here http://www.fiero.nl/forum/Forum2/HTML/118019.html
        • ericjon262
          build it.
          • Jan 2010
          • 2218
          don't scare me with pics of destroyed pistons! my 3500 should be here thursday!
          I'll keep it in mind, but I'm going to wait till the motor gets here and see just how bad it is.
          • hookdonspeed
            • Jun 2007
            • 322
            LOL! yea, idk wtf happened to that first one but hey, im putting another one in if ya got any Q's just hit me up, ive done it all once... lol
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              I'm planning on adapting the retunless fuel system the same way you did, I read all over where people were trying to swap fuel lines and rails and whatnot, and I wondered way no one just put a reg in there!
              I just hope I can get away with a stock replacement clutch for now, I just can't spring $300 for a centerforce right now, and I'd rather not put the swap on further hold...
              • hookdonspeed
                • Jun 2007
                • 322
                id be afraid to do that, your looking at about a 45% hp increase(140 to 215ish) over the factory 2.8, guess if your not laying into it hard youll be ok... but i couldnt resist doing that :P
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  yeah, I'm afraid of doing it the wrong way, and my wallet's afraid of doing it the right way...
                  Right now, while I wait for the engine, I decided I should make room for the exhaust...
                  Grind away the goop
                  Cut out trunk floor!
                  The way I'm doing it, I will still have a trunk, It will just be smaller, and I'll have room for real mufflers!
                  • Kaiju Senso
                    • Sep 2010
                    • 82
                    I'll let you know if my (new) stock Fiero clutch slips with my 3400/3500 Equinox engine. It's rated about 20 horsepower less so if it slips then yours definitely will. If not well...I won't be of any help now will I
                    • ericjon262
                      build it.
                      • Jan 2010
                      • 2218
                      well, I'm looking into a spec stage 2, and a centerforce dual friction, I'm gonna call my speed shop tomorrow.
                      • ericjon262
                        build it.
                        • Jan 2010
                        • 2218
                        well, things are starting to come together, I need a few more parts, the big ones being a clutch and a HTOB, before I can throw it in and begin mocking up headers!
                        • hookdonspeed
                          • Jun 2007
                          • 322
                          whats the HTOB need to be from?
                          • ericjon262
                            build it.
                            • Jan 2010
                            • 2218
                            It would be one from an '01 cavalier, I already have one, but I don't know how it was treated, so I'm going to get a new one.
                            • hookdonspeed
                              • Jun 2007
                              • 322
                              ill send u the price of a new one when i sending u the shipping quote 2morrow morn. (i work IT for a parts chain)
