roller lifters with 2.8
    MUCH better.
    Even though the runners are different lengths i think you'll be ok. Guys that run ITB's have been known to alternate the height of velocity stacks to change the power band of the engine. From what i hear it works pretty well.
    • onefastV6
      • Sep 2005
      • 880
      #227
      I think the last design is going to be where it is at.
      As always, your work looks great.
      2000 Grand Am GT
      2011 Chevy Impala
      • 1QUICKHATCH
        • 387
        #228
        Cool build! if you could figure out some way to seal every thing up and leave it open under the plenum you would have a v6 "air gap"!
        14.96@91.47 in the 1/4
        9.63@74.36 in the 1/8th
        • TGP37
          Shadetree Engineer
          • Jul 2011
          • 1027
          #229
          Originally posted by veekuusi View Post
          We have had a pretty good squirrel year this year.
          Funny, I have a squirrel family in my garage rafters. They found a nice entrance on the roof from the trees. I leave them a pile of food when they seek the lands for acorns, etc. They sure do appreciate my presence as I turn on the heat....lol.
          One of the babies (eyes still closed) fell onto my work bench, alive. With out touching it, I scooped it up and placed it outside where the momma often runs around. An hour plus some she found it and scooped it up. I was surprised, I thought the baby was as good as dead soon.
          Wife loves that story.
          • bob442
            Show Me Your KITS!
            • Nov 2008
            • 1305
            #230
            Yeah I wouldn't want those things living in my garage festering diseases and crapping everywhere.
            • veekuusi
              • Aug 2011
              • 205
              #231
              2 years ago we had a one eye squirrel in our yard.
              I saw it for some 1.5 years, it visited our yard allmost every day.
              Some kind of accidents had happened.
              But one day it did not come anymore.
              • Purple pit
                • Oct 2012
                • 718
                #232
                That is about how long our squirrels seem to last. I don't know if they move on or get killed. They seem to like to dig around(work) on cars. I always see them under the cars pawing around for close to five minutes.
                Your squirrels have some nice colors!
                We even have flying squirls here.
                Grand Prix trans with 3.33FDR
                • TGP37
                  Shadetree Engineer
                  • Jul 2011
                  • 1027
                  #233
                  They are in the rafters over the dead side of the garage. They leave me and my stuff alone (except for dropping infant squirrels lol), so I leave them alone.
                  The moment they mess with my stuff, they are target practice.....and I think they know it.
                  • veekuusi
                    • Aug 2011
                    • 205
                    #234
                    "Third time tells the truth".
                    We have here a saying like that , lets see if it is true or not.
                    21 of february is the third dyno day , so in a 2 weeks time.
                    But I have to make a disappointment to some of you.
                    It is with the PMO carb not with the Holley.
                    The Holley intake has not seen any progress, it is all of motivation.
                    First I want to see this final change to the 3 barrel carb intake.
                    With the bigger and lower plenum tubes.
                    When I welded it , it changed its shape a lot.
                    It did not match at all the heads any more..
                    I had to fill the runners and take it to the shop to have it milled.
                    But now it is okay.
                    Here is a summary of the engine parts (chevrolet 2.8 V6):
                    -block 1996 3.1 (gen 3)FWD bore 89.25 , stroke 76 mm
                    -3400 aluminum heads (gen 3)
                    -crank Eagle 2.8
                    -pistons Diamond custom
                    -Total Seal piston rings
                    -Manley stainless steel valves 1.76" / 1.42"
                    -camshaft Schneider 258/264 (.050") , lobe separation 106 , valve lift 13.2 mm (0.520")
                    -mechanical roller lifters (Crane)
                    -double custom valve springs closed 175 lbs, open 445 lbs
                    -roller rockers (Crane) 1.6:1
                    -custom push rods (Comp Cams)
                    -compression ratio 12:1
                    -Scat connecting rods 5.700"
                    -custom intake
                    -PMO 3 x 50 mm carb (37/39 chokes)
                    -ignition 6 x 034 Motorsport coils
                    -ECU Gems EM36
                    -spark plugs NGK BCR8ES
                    -custom exhaust 38 mm ID 3-> 1
                    -ATI damper
                    -electic water pump Davies Craig (EWP 115)
                    -dry sump AT-Power (3 stage)
                    -bellhousing Chevy S-10 5-speed (82-92)
                    -2 disc Alcon clutch
                    -gearbox 5-speed "dog box" Sellholm M47000
                    • ericjon262
                      build it.
                      • Jan 2010
                      • 2218
                      #235
                      here's the intake I think you should build!
                      Please excuse the quick and dirty sketchup screenshot... I bet that would work really well with the 3 bbl and a largish open plenum!
                      • TurboGTU
                        • 453
                        #236
                        On that eagle crank were you able to internally balance it or did the shop had to externally balance it with the flywheel?
                        • veekuusi
                          • Aug 2011
                          • 205
                          #237
                          Free Shipping - Eagle Cast Steel Crankshafts with qualifying orders of $109. Shop Crankshafts at Summit Racing.
                          The shop managed to balance it internally, although this crank is ment to
                          balance externally (with a flywheel).
                          As I said earlier, "the second most difficult balance ever", they said in the shop.
                          It did not come cheap, $ 800 (read: 800 bucks!).
                          They say, this crank can take 300 hp, I am coming closer to that limit.
                          • veekuusi
                            • Aug 2011
                            • 205
                            #238
                            I totally agree with you.
                            But in reality the intake runners are not going to be as long as
                            they are in your drawing.It is the 60 degree that makes it difficult.
                            Cylinder heads are in our case much closer together than in a V8 engine (90 degree).
                            But lets wait a 2 weeks time, we are much wiser then after the third dyno day.
                            And here is some really hot pictures of V8 intakes.
                            It is easier for the V8 guys, there can be a flange towards the heads,
                            and the push rods do not came in the way of the runners.
                            And I have an issue with the hood.
                            I had to shorten the air horns above the carb.
                            If it would be possible to make a scoop to the hood, no problem at all.
                            • TurboGTU
                              • 453
                              #239
                              Yes I did see that they had a hard time. But didn't know if it was balance externally. Wow 800. If I can't get a factory forged when I buy a 3.5l lx4 or a 3.9l lx9 I am thinking about that eagle crank. Guess I better send a flex plate with it to keep cost down.
                              Thanks
                              • ericjon262
                                build it.
                                • Jan 2010
                                • 2218
                                #240
                                Lol, hogan doesn't have crap on Marcella!
                                but nah, I get it on the runners, and the drawing I posted was by no means to scale, the runners aren't even offset! but a large-ish open plenum under your 3BBL would be ideal in my eyes.
