3900 LZG Cam Specs
  • NateD4
    • Mar 2011
    • 576
    3900 LZG Cam Specs
    For anyone interested here are the 3900 LZG stock cam specs:
    Intake:
    @0.005 lift:
    252 Duration
    110 Centerline
    @0.050 lift:
    189 Duration
    Peak lift: 0.270" at the cam
    Exhaust:
    @0.005 lift:
    276 Duration
    114 Centerline
    @0.050 lift:
    197 Duration
    • 13531
    Where did you get that? I thought it was the same as a 3400 cam but with larger lobes.
    • NateD4
      • Mar 2011
      • 576
      Degree wheel and dial indicator.
      I have the profile for the exhaust cam done to 1 degree precision. I have to do the intake next. Then enter them in Excel. currently their are about 410 readings for the exhaust cam with about +/- 0.0005 to 0.001" lift accuracy.
      Should let me find the total time the valve is open and integrate the air flow with respect to both time and crank angle. I should also be able to generate the valve train forces as well.
      We'll see how well it works.
        O.o
        Who needs Crane, ect to ID a cam... you are a thorough man...
        • NateD4
          • Mar 2011
          • 576
          Anything worth doing once is worth doing right the first time.
          Must be the engineer in me.... Plus I'm trying to pushing RPM limit with the DOD system. Need to have the data to tell me the loads on the valve train and to help predict float. Again a bit of trial by error....
          • Kenova
            • Nov 2011
            • 16
            I don't know if this applies to the 60V6, but I have read that the V8s using DOD have different lobe profiles for the constant cylinders and de-activated cylinders.
            Ken
            • NateD4
              • Mar 2011
              • 576
              I verified the lift differences. It is done to remove play from the lock pin for the DOD in the lifter. The ramp angle is also slightly different.
