http://foreverpontiac.com/index.php?...20&#entry59531
"I'm am working on fixing the PCV issue today. I can tell you right now it's NOT the piston rings though. He has no clue wtf he is talking about on that one... they are good. I did everything by the book so there's no way they could be bad. Regardless I'll be doing a compression test as soon as I can get a good compression tester, just so he'll shut up about the rings. My compression tester has a bad pressure relief valve and isn't holding pressure like it should."
Yes, I took a guess at what was wrong based on what your engine was doing, and that might not be it. I hope I am wrong, considering you have found 1 source of oil.
