Let's talk about cams!
    • 9189
    #46
    I am 99.9% sure it will still work. In fact, WOT-Tech even lists 3100/3400/3500 cams the same: http://wot-tech.com/shop/gm-60v6/sto...t/prod_67.html The cam trigger has changed over the years, but we have determined that they all operate on the same principle, so it shouldn't be an issue.
    • NateD4
      • Mar 2011
      • 576
      #47
      The sensors don't matter as much as the waveform they output to the computer.
      • ericjon262
        build it.
        • Jan 2010
        • 2218
        #48
        yeah, but I can change a sensor in the car, I can't change a cam in the car.
        • NateD4
          • Mar 2011
          • 576
          #49
          The LZ series cams have three metal tabs that indicate cam position, one of which is long.
          The LA1 cam I have has a disc with a notch cut from it. So clearly the position on the LA1 is output differently.
          Not sure about the LX engines. Someone probably has a picture of one.
            • 13522
            #50
            All 3100 3400 and 3500 LX9 cams are compatible with each other. The 3900 cam is not compatible in any way.
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              #51
              Ok, thanks for clearing that up for us, I'm glad to hear that I don't have to do a cam swap to run obd2!
