  • ericjon262
    build it.
    • Jan 2010
    • 2218
    #76
    well gents, I've made the plunge and bought a GT35... more to come soon...
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      #77
      Gentlemen, in the darkness, there is light!
      • ericjon262
        build it.
        • Jan 2010
        • 2218
        #78
        worked a bunch on my shift linkages today...
        should be enough room under the shift cables for the turbo.
        I also started re-doing my front mounts.
        • ericjon262
          build it.
          • Jan 2010
          • 2218
          #79
          power steering may not be out of the question, even with the intake flipped! pics tomorrow!
          Also, I'm pretty much done with the front engine mount, now I need to get more pipe to make my turbo headers, and put the engine in the car!
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            #80
            Awesomeness!
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              #81
              here we go!
              the pump would be mounted facing the opposite direction from normal, and would use a smooth pulley to get the correct rotation, it will also mount the pump a little higher than in the pictures, essentially over the cam gear.
              I'll make a mount that goes over the timing cover, catching boltholes near the red blobs.
              • ericjon262
                build it.
                • Jan 2010
                • 2218
                #82
                found a better way to mount it, and it's about 3/4 of the way done!
                The plate across the front will catch on this bracket near the a/c compressor.
                it's not done yet, but it's getting there quickly!
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  #83
                  well, I've got a little bit done today, I began re-wiring the engine for the third time, and I'm going to try to do a mock-up in the car later this week. so I can get the shift cables and turbo situated... I also got some parts on order from CNCguy, new header flanges, and some spacers for the intake.
                  • ericjon262
                    build it.
                    • Jan 2010
                    • 2218
                    #84
                    well, the front side trans mount is done! (finally!) now back to the power steering pump mount, hopefully that will be done this week too, then I may start over on the shift linkage to make more room for the turbo, but that may have to wait until I have the engine mocked up in the car...
                    • unchained01
                      • Jan 2011
                      • 388
                      #85
                      looks good ao far nice wortk !!!
                      • ericjon262
                        build it.
                        • Jan 2010
                        • 2218
                        #86
                        thanks! it's been a chore!
                        • ericjon262
                          build it.
                          • Jan 2010
                          • 2218
                          #87
                          well guys, I hope this isn't a slippery slope, but I'm buying a cam on payday...
                          • Kaiju Senso
                            • Sep 2010
                            • 82
                            #88
                            You've been on a slippery slope since you decided on a turbo . Did my cam swap put you over the edge? At this rate you'll be building a car forever and not driving it haha. Can't wait to see it done.
                            • ericjon262
                              build it.
                              • Jan 2010
                              • 2218
                              #89
                              LOL! hopefully not!
                              • carbon
                                Procrastinator
                                • 388
                                #90
                                I have been contemplating a cam as well, but I won't be doing anything really supportive of a cam... no head porting or header building. So I am kind of on the fence. I am trying to figure out if there is more in the engine stock that a cam could free up...
                                - Ben
