  • ericjon262
    build it.
    • Jan 2010
    • 2218
    #241
    Hi I am just now putting my 3500 in my M4 Fiero, and had a question...
    AFAIK the trigger mount is supposed to be mounted right to the block, and not sandwiched between that front motor mount. Has that caused an issue at all ? Or is the wheel thick enough that it has no effect ?
    Thanks. Cool build.
    I couldn't imagine a turbo 3500 Fiero, WAY WAY too much power for such a scary handling car. haha.
    the sensor holder is different on my car now, I'll try to get a pic, it's also adjustable.
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      #242
      Originally posted by bigcheese View Post
      cool can't wait to see pics. Are your headers almost done?
      LOL, I haven't re-started them yet, I did get a new welder though.
      • ericjon262
        build it.
        • Jan 2010
        • 2218
        #243
        Thanks. Cool build.
        here's a picture of the revised mount. Marc (CNCGuy) made this one.
        I need to blast it and paint it though, along with most of the other parts.
        Edit: the sensor isn't in the holder all the way, but when it is, it has the correct spacing, and can be adjusted slightly.
        • ericjon262
          build it.
          • Jan 2010
          • 2218
          #244
            Looks pretty good. Member on here do those for you? You don't have to divulge info if you don't wish to though.
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              #246
              The porter wished to remain anonymous.
              • Mars
                • Apr 2004
                • 826
                #247
                Oh cool, I think I'll just cut a chopsaw blade thickness out of mine, then weld it back together I guess. Should work.
                I think I may know whom the great mysterious porter of 2012 might be, haha.
                • Mars
                  • Apr 2004
                  • 826
                  #248
                  Oh sorry, one more question..
                  Do you have this wierd motor mount on the pass side towards the front of the car that is kind of like a little shock looking thing ? Did you re-use that with your 3500 ?
                  I was going to fab something up out of all solid steel...
                  • ericjon262
                    build it.
                    • Jan 2010
                    • 2218
                    #249
                    I was going to do the same with mine, Marc offered to swap it though, so I did. mine was unused though.
                    • ericjon262
                      build it.
                      • Jan 2010
                      • 2218
                      #250
                      I ditched mine I'm looking into something else to go near where it was. you'll have to use the fiero timing cover to make it work IIRC.
                      • caffeine
                        • Jan 2012
                        • 1489
                        #251
                        I just ditched that shock looking thing on my Fiero and an running a solid dog-bone and poly trans mounts.
                        '86 Fiero, 3500, 4-speed
                        • Driver_10
                          • Jul 2006
                          • 487
                          #252
                          This is a really nice build-up. Your engine build is pretty similar to my own, save for a few engineering details. I really like the aluminum welding fab work that you did on the tank too. By comparison, my aluminum welding looks like goat-shit on a tin plate. Im also running a similar Water-to-Air set up as you own, only Im using a larger IC and a slightly smaller heat exchanger.
                          Using a factory ECU will give you less down time since you have a viable base tune to work with. By comparison, I will have a staggering number of settings to input get working PRIOR to tuning. I look forward to seeing more of this build.
                          • ericjon262
                            build it.
                            • Jan 2010
                            • 2218
                            #253
                            I wish those were my welds on the tank, but they were not... these are my welds (first time on aluminum!)
                            !! now I need to invest in a spool gun!
                            • Driver_10
                              • Jul 2006
                              • 487
                              #254
                              That's some really nice porting work. Ill be sending my heads and LIM back to John and Ben at some point to get some additional porting and a spring upgrade due to some slight changes in the plan..
                              I want a 7500rpm red-line (actual shifts at/ or slightly below 7000).
                              • ericjon262
                                build it.
                                • Jan 2010
                                • 2218
                                #255
                                I'm thinking about the same, shifting at about 7200, we'll see once I start tuning it though.
