  • ericjon262
    build it.
    • Jan 2010
    • 2218
    #781
    I got the shift cables in, and a shifter built. in it's current condition, if functions more or less as desired, but the select cable is way to close to the strut tower, I'm going to take it back off and make some adjustments to it to move it off of the strut tower which should improve cable life and shift feel. Note, the "E" clip that holds the select lever in place isn't installed and the lever isn't fully seated in the picture.
    in other news, I'm getting alot closer with the wiring nightmare. It may not look a whole lot different to the untrained eye, but it definitely is a huge improvement over the older stuff I had done, and MIGHT fit behind the console without chopping it up. the engine harness is able to be divorced from the chassis harness via 3 connectors, a 3 pin that holds the reverse light wiring, a 16 pin that holds the power, ground, and switched chassis inputs to the MS3, and a 5 pin connector on the MS3 that houses the CAN bus link.
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      #782
      The wiring to the new fuse panel is terminated, and the wires I had run to the C100 now extend into the front trunk. long term, I'll use these to power high demand loads like the headlights, cooling fan, and intercooler pump, for now, I think I'll cover the ends and leave the fuse in the engine compartment out.
      I also removed the spare tire tub, at one point I installed a crappy remote battery tray in it, but now that I don't have a battery there, I don't want it in there, there's a guy local to me who is trading a stock tub for it, so everything works out well. I'm also getting a "new" set of AC lines from him that I'll install while the tub is out. I also took a minute to open up the HVAC hox and make sure there wasn't any debris in there that would want to catch fire when I power the car back up.
      I also pulled apart another bulkhead passthough and installed it over the wires running through the firewall, it looks much cleaner, and will seal up the giant holes better. they aren't permanent yet, and I don't think I'll use glue to seal them like the factory did, so that if I need to run a new wire I can do so more easily.
      Along with the new AC lines, I picked up a new to me passenger coolant tube, I had cut and welded mine to clear the 88 rear suspension. When I welded it I did a piss poor job and ended up with a leaky mess, so I went the redneck route and JB welded it. Please excuse some of the potato quality pictures...
      The new tube was an 87, so the heater return tapped into the tube and didn't return directly to the engine, with my LX9, I can do the same thing because the engine doesn't use a recirculating cooling system like a Northstar, an LSx engine, or a later model VVT 60V6. Those engine need a dedicated return path or the heater will only work with the thermostat open. The tap for the heater return is on the back of the tube near the engine, which honestly doesn't make much sense to me. I did some calculations and determined the pressure drop across the tube from front to back, not accounting for the bends works out to about 2 PSI, this was assuming a 7500 GPH(125GPM) flowrate (obtained from ASE website linked below) that figure also assumes full flow through the tube, with no flow through the bypass line or heater lines. After seeing the math, I determined that there isn't a reason not to move the nipple forward on the tube to the front crossmember. I already had the front tub out, so I removed the existing tube.
      the new tube is far, old is near
      The heater return nipple
      The proposed new location
      I installed the new tube, set the spare tire tub in, and marked the tube from above through the cowl drain.
      with the tube marked, I pulled the tub and tube, cut the nipple off the back, drilled a hole and welded the tube up front. Somewhere along the line, I misinterpreted my mark, and put the nipple on at an angle that isn't exactly ideal, if I ever need to pull the tube again for some other reason, I'll consider welding it in more vertical like my finger is pointing.
      I then attached a hose, and did another test fit, the hose is close to the spare tire tub, but I don't think it's close enough to warrant cutting it back apart.
      Now, you're probably wondering why go to the trouble? it's now one less line that has to be run underneath the car, I can also repurpose this line for the A2W intercooler which means I would only have to run one new line. it's also a DD friendly weight reduction mod. admittedly, the tube probably doesn't weigh enough to make a huge difference, but every little bit helps right?
      now for the other half of the work, my old tube was mess up because it didn't clear the 88 rear suspension links, can you take a guess what also doesn't clear? yep, the new tube, I figured this would be the case, which is why I was ok with cutting the nipple off of the back of the tube, as I knew I would have to cut and weld the pipe to make it work.
      here's the new pipe prior to any cutting, you can see the bolt for the longitudinal link is right up against the tube...
      I cut the end off, and rotated the whole pipe up so it now make a turn into the wheelwell.
      Next I took a cutting from the old pipe, and added a 90 to the end of the tube, pointing it into the engine bay.
      The final step was to cut the rolled end off of the old pipe, and weld it on so the hose is less likely to fly off under pressure. now everything clears and points enough into the engine bay to make hose installation easy, but not so far that it makes engine removal or installation difficult.
      Now, what if I decide to install a newer engine like an LZ9, with a recirculating cooling system? I came up with a very simple solution, do the came thing I did to the front, to the rear. add a nipple at the water pump suction connection and the heater will again function. the downside to this is that the engine may take slightly longer to warm up based on the much larger volume of cool water in the tube vice a dedicated line. I didn't do any math to prove or disprove this, but I don't think it would be anywhere near large enough of a difference to matter.
      7500 GPH data source. note this describes a typical pump, my LX9 water pump could be more or less, and the number is an exageration either way based on multiple coolant flow paths that don't (didn't) go through the tube like the bypass line and heater core. I suspect this number is higher than the design flow of my LX9's pump.
      A mid-depth cap with classic style for any occasion, this Nike Club Cap comes in smooth cotton twill that's been softly washed for casual, daily comfort. Soft and unstructured, the precurved bill makes for easy styling, and the adjustable back-strap lets you find the right fit. Nike Hat Size 6 1/2 6 5/8 6 3/4 6 7/8 7 7 1/8 7 1/4 7 3/8 7 1/2 7 5/8 7 3/4 Head Size (CM) 52 53 54 55 56 57 58 59 60 61 62 Alpha Size - - XS - S - M - L - XL Swhoosh Flex - XS/S XS/S XS/S - W77 XS/S - W77 W77 - SITUS W77 - OS W77 - SITUS W77 - OS W77 - SITUS W77 - OS W77 - SITUS W77 - OS SITUS W77 - XL-XXL SITUS W77 - XL-XXL Adjustable SITUS W77 XS XS XS - S - OS XS - S - OS XS - S - OS XS -S - OS S - OS S - OS - XL OS - XL OS - XL XL Adjustable Women's S S S - OS S - OS S - OS S - OS OS - L OS - L L L L - - - XS/S - W77 - SITUS W77 - W77 LOGIN - Dual Size Women's - - W77 - SITUS W77 - W77 LOGIN - - - - Size Disclaimer: There may be a 1-2cm difference in measurements depending on the development and manufacturing process. Color Disclaimer: Actual colors may vary. This is due to the fact that every computer monitor has a different capability to display colors, we cannot guarantee that the color you see accurately portrays the true color of the product.
      • ericjon262
        build it.
        • Jan 2010
        • 2218
        #783
        well, long time no real update... I bought some MIDI fuses and began providing electrical power to the car again for the first time in about 2 years... so far, everything appears to work, except for the MS3 Pro...
        The MS3 Pro is refusing to connect to my laptop... I've been emailing back and forth with AMP EFI about the MS3, no conclusions yet... last paycheck I got a bonus that I was going to use for other stuff, but ended up buying a new controller with the idea that if the one I have really is dead, I can get the car moving while the one I have is being repaired (I can dream right???), and when it is repaired(don't shatter my dreams) I can use it as a spare, or for another project yet to be disclosed... Lol...
        I ran into some other odd issues with the DBWX2 that had me sweating big time and wondering if the fault was my computer(s) it flat out refused to fully connect to my laptop... it would be recognized by tunerstudio, but not actually be available to adjust settings or tune...
        if I tried updating the firmware, the updater flashes the red message saying it can't connect, and to close the "bootloader switch". that screenshot was pretty hard to get BTW, as it automatically closes the window when it does that.
        The portcheck utility was also able to see the DBWX2 the firmware...
        after reading the manual a dozen times, I enlisted the help of the MSextra forum, and was told my current firmware was ANCIENT! I was provided an older version of the firmware updater, and told to try it, and sure enough, success! and what a relief that was! I began checking the parameters of the throttle and pedal position sensor, got everything calibrated, deleted the fault codes associated with the out of calibration parameters, and now the throttle works like a champ.
        Hopefully the new MS3 gets here tomorrow so I can actually start some subsystem testing and troubleshooting before I pull the engine back out of the car to install my clutch and flywheel.
        • Xionation
          • May 2020
          • 1
          #784
          Amazing build. What a journey. I came about the forum looking for 60* info. Stumbled on to your build and have read the entire build over the last two weeks. I was surprised that you are from Pensacola. I leave in Lillian, AL. To see this evolved is amazing. I even read the Pig Rig build. Awesome. Keep up the great work. Good luck with all you do.
          • ericjon262
            build it.
            • Jan 2010
            • 2218
            #785
            Thanks, it's been a long time work in progress, with lots of highs and lows. I still DD the Pig Rig, it's not fast, and it handles like an elephant swimming in jello, but it's somehow more comfortable than my 2006 2500HD.
            Bought a molded cable thinking I could cut one end off and wire it to the M12 connector but I needed to determine which wires were pins 2, 3, 5, and 9 on the DB9 so I could proceed... wouldn't you guess that while trying to ohm the wires, pin 9 shows over-range for all the wires, (along with pin 1...)
            Since I had already cut the cable in half, I figured there was no sense in not ripping it apart to see whats up, and what do I find? Pins 1 and 9 weren't even soldered in, not a drop in either pot... erg...
            Since I didn't have a clamshell DB9, and I didn't think I would need one, I gutted what remained of the molded DB9 and made my own dongle to connect it to the Keyspan Serial-USB adapter.
            I checked resistance of each pin, and found each wire to have less than .02 ohms resistance, and over-range between parallel circuits, just as nature intended. Unfortunately, all this work was for nothing, as the MS3 still won't connect. I'm almost positive it's a dud at this point, I can't think of any other logical explanation why it won't communicate when other hardware does just fine...
            • manbearpig
              • Oct 2017
              • 59
              #786
              That's because pins 1 and 9 are only used on ancient computer hardware... namely serial modems.
              Here's a basic USB to serial circuit...
              • ericjon262
                build it.
                • Jan 2010
                • 2218
                #787
                The cable had 9 conductors (10 if you include the shield) inside... there was no reason not to connect them... That being said, looking at the reviews for the cable i bought, and there were a bunch that had problems with different pins not being connected to anything. I ended up using a Keyspan USB adapter, I would spend way to much time making one for it to be worth not dropping $25 on something proven.
                • manbearpig
                  • Oct 2017
                  • 59
                  #788
                  I wasn't suggesting making one, I just posted that to show you that you only need the transmit and receive lines and a ground (pins 2,3,and 5) to have RS232 serial communications. All the other pins are long obsolete...
                  • ericjon262
                    build it.
                    • Jan 2010
                    • 2218
                    #789
                    Gotcha, the MS3 wiring guide says pin 9 is needed, so I used it. I'm not much of an electronics technician...
                    how to become EXTREMELY frustrated in 10 easy steps...
                    1. Install blown fuse (not knowing it's blown)
                    2. power up MS3, and see lights on the front that indicate it has power.
                    3. not be able to connect to MS3.
                    4. repeat steps 2-3 several times by various means.
                    5. contact AMP EFI customer support.
                    6. repeat steps 2-3 several more times.
                    7. learn that the lights on the front only indicate it has IGN+ power, and have no bearing on whether or not it has B+ power...
                    8. Read step 7 again...
                    9. get multi-meter out and check fuse for B+ to the MS3
                    10. Replace fuse, connect to MS3 and kick own ass for the next 24 hours.
                    • manbearpig
                      • Oct 2017
                      • 59
                      #790
                      Hmm, well if it's using pin 9, then you would need a full port emulator and not just a USB to RS232 adapter, which is what the cheap ones are. Could explain why it wasn't working.
                      • ericjon262
                        build it.
                        • Jan 2010
                        • 2218
                        #791
                        it wasn't working due to the B+ fuse being blown like mentioned in my above post. The above pictured dongle connects to a Keyspan serial to USB adapter, which emulates a com port.
                        • ericjon262
                          build it.
                          • Jan 2010
                          • 2218
                          #792
                          The new MS3 ended up leaving Monday afternoon or Tuesday morning... I was surprised when it arrived this morning while i was at work. I can send it back, but I'm going to hang onto it, eventually, I'll have another project I can use it on, like the R07 I'm slowly amassing parts for...
                          I got my new PTFE fuel line in, and started assembling lines. I have the feed line from the filter done, and the return line from the regulator halfway done.
                          I decided I'm going to tap the heater supply on the lower intake, and install a 1/2" NPT to -10 AN fitting , then route the heater supply around the front of the engine instead of behind and around, it should make for a much easier installation, and be WAY faster to fabricate. Assuming I get out of work at a reasonable hour tomorrow, I might pull the engine back out and get the cradle and mounts painted, as well as the flywheel and clutch installed, then Friday and into the weekend, I'll reinstall it and really start getting things rolling. Tomorrow, I'm going to generate a list of things I need to accomplish, and hopefully by the end of the weekend, 90+% is done, but we'll see.
                          • ericjon262
                            build it.
                            • Jan 2010
                            • 2218
                            #793
                            Bleh... what a shit weekend...
                            I pulled the engine, installed the flywheel and clutch, and tacked together a respectable downpipe. Fun fact, the horrible freight belt sanders aren't half bad, in fact, I wish I had bought one 10 years ago, they make squaring up joints so much easier... One day, I'll get or build a nicer one.
                            Call me a crazy asshole, but that's what the exhaust will be for now. I may put another pair of 90's on it so it exits under one of the bumper cutouts, but for now, I ain't worried about it.
                            I haven't decided whether or not to divorce the wastegate dump from the rest of the exhaust or not yet. if I divorce it, it will follow the downpipe until it's near the axles.
                            here's the new heater core line, routing in front of the engine avoids more hot or moving parts than around the rear of the engine.
                            boring picture... I mounted the fuel filter. Riv-nuts are awesome!
                            I made a list... it's longer than I hoped...
                            To start...
                            Fuel lines
                            turbo oil lines
                            oil+filter
                            O2 sensor(finish wiring and install bung)
                            MAF bung
                            Charge piping
                            Fully weld the downpipe
                            Waste gate dump
                            BOV install
                            other end of heater core supply line
                            driver's side rear cradle bolt...
                            Paint the alternator and belt tensioner brackets,
                            Terminate the starter trigger wire.
                            waterpump and thermostat hoses
                            install a thermostat...
                            Find TDC/Mark on the balancer.
                            Torque motor mount bolts
                            add transmissino fluid
                            Make a stock dipstick work, or fabricate something that will work.
                            Port the plenum to match the lower intake.
                            Hopefully I can get some of the bigger items on this list done this week, it would be awesome to start this POS before I go back out to sea.
                            • ericjon262
                              build it.
                              • Jan 2010
                              • 2218
                              #794
                              I dropped the fuel tank to get at the fuel lines, I figured getting the old gas out was probably a good idea, there was way more in there than I expected, and it was nasty. I think to be safe, I'm going to go ahead and toss a new pump in, and a new gauge sender if I can find one.
                              • ericjon262
                                build it.
                                • Jan 2010
                                • 2218
                                #795
                                I got my fluke out and checked the resistance of the level sender... 50+Megaohm across the board... well, that won't tell me much will it... Since I still refuse to buy stuff from the fiero store, I really don't have any options but to either get another used sender and hope to get better results, or to make something, so I ordered this
                                it's a universal 0-90 ohm sensor, I'll take it apart (carefully) and install in on the stock pickup, I think it should be a simple enough thing to fabricate.
                                I also ordered a new fuel pump, while it's not hard to pull the tank and replace the pump, I don't want to do it unless I have to, and since it's out I'll do it now and know it's good for the long haul.
                                here's the pump, I've always heard good things about them, and I've seen independent testing that shows comparable or better performance than Walbro pumps
                                FREE 2-DAY SHIPPING, EASY INSTALL from the AUTHORITY on OEM replacement Fuel Pumps. SAVE up to 70% off on parts for your Pontiac Fiero 85-88 with QFS-343FT-1016
