96 3400 with fiero heads
  • newfiefiero
    • Oct 2011
    • 24
    Hi, I'm new to this site.. I have a 1986 Fiero 2M6 with a shot 2.8L. I have a chance to get a newer 3400 (96-97ish) and I was wondering if the 2.8L heads and intake will fit? The reason I'm doing this is for simplicity and to keep the stock look. I know that this will probably hurt the performance, but this is just a daily driver for now..
    Thanks!
    • 9191
    First off, welcome to the site!
    To answer your question, yes, the heads and intake will work on the 3400 block. Just make sure you save the 3400 top end for future use...
    Brad via Tapatalk
      Live life 3.7mi at a time
      • 4555
      Hurt performance isn't the words. You will have extremely low compression.
      Welcome to 60V6!
      • newfiefiero
        • Oct 2011
        • 24
        How low are we talking? I can get the 3400 for a really good price (too good to pass up!) and I don't really want to have to change the computer..
          • 13531
          7.6:1, you need 3.4 iron head pistons in there to make it proper and you cannot use the iron head head gaskets either.
            • 4555
            Yup. Change the pistons to units from a 3.4 Camaro, put the iron heads on and you have a 3.4 upgrade like the Camaro block, but you have a roller cam, better oiling etc.
            • newfiefiero
              • Oct 2011
              • 24
              Well, I think I've changed my mind.. I can get a 2001 grand am 3400 engine, wiring harness and computer for 100 bucks. I think I'll suck it up and do a bit of wiring for the extra power.. I'm sure I'll be asking many questions before it's all done!
              • ericjon262
                build it.
                • Jan 2010
                • 2218
                Welcome to the dark side!
                • bob442
                  Show Me Your KITS!
                  • Nov 2008
                  • 1305
                  X2!
                  • newfiefiero
                    • Oct 2011
                    • 24
                    Thanks! I figure why try to keep it stock looking if I can get more power for cheap?? I was contemplating a vortec v8 swap, but I smartened up pretty quick when I found out how much it would cost initially, even though I was given a vortec by my brother..
                    • bob442
                      Show Me Your KITS!
                      • Nov 2008
                      • 1305
                      they are heavy(cast block) and a FWD trans wont like it too much. the only hard part about this swap would be getting the gauges to work properly, i dont know if they use the same signal or not, hopefully a fiero darksider with chime in for that answer.
                      • Joseph Upson
                        Nope. In relation to a stock Fiero, putting iron heads on an aluminum head motor is the darkside. Swapping in some aluminum while at the same time loosing some weight and gaining more power and a roller cam is all "light" as in eureka!
                        • newfiefiero
                          • Oct 2011
                          • 24
                          Yup, lighter+more power just makes more sense.. There will definately be a turbo in the future too! I used to have a turbo colt and that thing could haull a$$! I'm kinda sorry I sold it but I needed to to focus on the fiero..
                          Here's the link the my colt build: http://www.cardomain.com/ride/216031...itsubishi-colt
                          Well, the guy got back to me and said I could have a 99 or 03 engine.. Which one would make more sense to get??
                            • newfiefiero
                              • Oct 2011
                              • 24
                              That's what I figured
                              4 years newer and the same cost! I just didn't know if there was any significant differences in the years.. I checked the family tree on this site and it seems like they are pretty much the same..
