header tips.
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    header tips.
    I'm in the process of making headers for my 3500 Fiero swap, and thought I might share a few tips I've learned along the way.
    1. FITMENT FITMENT FITMENT! Pipe fiment is everything! if you want clean good looking headers inside and out, make sure the pipes fit perfect before you start welding. this means the primary tubes fit where you need them, and that there is no gap when you but them together where they will be welded. if they don't fit perfect, they are not ready to be welded!
    2. find a comfortable place to work. don't work sitting on concrete where you cant be upright and have full range of movement, it makes a big difference in the finished product!
    3. Check your machine before every weld!
      IE: on my welder, the power switch is right next to one of the heat switches, if I'm not paying the utmost attention, I may inadvertently switch to high heat from low and start blowing holes instead of welding.
    4. tack tack tack, then weld.
      on each seam, start with for tack welds, do one at 12 o'clock, then 6, then 9, then 3, if you do one big seam, the pipe will warp and cause fitment issues. also don't weld the whole seam until you're sure it's where you want it, it's much easier to cut a few tacks than a whole seam.
    5. Invest in a high quality welder that uses a shielding gas, or tack the pipes with your welder, and have a friend or welding shop do the final welding. the welds lay down much smoother, and will seal better than with flux cored wire. Of coarse this mainly applies to those of us who don't have a TIG or are not Oxy Acetylene welding our headers.
    6. Invest in a tubing cutter or any other tool that can cut the full width of your pipe in one pass.
      it's much easier two weld to strait cuts than two crooked cuts, I picked up a pipe cutter for $20 at Lowe's (plumbing section) that will cut most header primaries no problem. funny, sounds like tip number 1 doesn't it?
      The best tool I have found thus far was a $20 chopsaw I got off craigslist, that I put an abrasive wheel in to cut the pipe, works like a champ, and produces nice straight cuts, minor deburing is required, but takes less than 5 minutes on a bench grinder. total investment, $25.
    7. weld the flanges and colectors LAST.
      it's easier to weld up the full length of your primaries when they aren't bunched together.
    8. If you're using the TCE 3x00 D-forming tool, weld some "ears" to it so it will hold itself in the vise for you.
    9. PRACTICE PRACTICE PRACTICE. order enough materials so you can practice on the same size and thickness pipe, it will help you get a feel for your welder, and the materials you are working with.
      I cut some straight pipe, and then keep welding and welding and welding until I find a technique and the settings that work best on my material.
    When I was done welding my primaries, I built a pressure tester that I could hook up to my air compressor to test my welds, it cost less than $20 to make, and has worked great so far,
    I made it out of an 1 1/4" PVC repair coupling, a 2" PVC cap, a air line coupling, some epoxy, and a rubber expansion plug.
    drill a 5/8" hole in the 2" cap, and epoxy the air line coupling in, the epoxy the 2" cap to the repair coupling.
    The repair coupling's threaded ring and washer will fit over a 1 5/8" primary that has been pressed into a "D" shape, and then you can tighten the coupling and it will seal against the outside of the pipe, the seal may not be perfect, but it doesn't have to be.
    then get the rubber expansion plug, and tighten it into the other end of the primary you want to test.
    now hook an airline up to the air coupling you epoxied to the cap, and apply pressure, I would not go past 25-30 PSI, you don't need to, and I don't trust the epoxy to that.
    Brush a mixture of your favorite dishsoap and water over the welds and look for bubbles, if you see bubbles, you have leaks!!!
    Some of the guys on the Fiero forum had a little to add.
    Originally posted by Arns85GT:
    The only thing I would add is that I used a common sink stopper and filled the tube with water to check my welds. This not only identifies holes but also when you have a thin weld which water oozes through. I wasn't satisfied until the tube was water tight.
    Arn
    Originally posted by gusshotrod:
    When fitting the tubes, bolt the header flange to the heads with SAE washers between the heads and the header flange.
    This will allow the tubes to go past the face of the flange and will give you some wiggle room. The tubes can then be ground flush with the flanges after fitting.
    The following only applies to Stainless Steel:
    Originally posted by Pete Matos:
    You forgot one of the most important things....you gotta flood the tubes with shielding gas or you will get some serious sugar crystallizing on the inside of the tubing. It is not hard to do and you can just put a Y on your gas line pretty easy and make some plugs or use some rubber sink stoppers with a hole in them for the line input.
    Also make sure you bolt your flanges down before you weld the tubes to the flanges or they will warp all to hell no matter what you do. Would not be a bad idea to get an old blown head to work on building your headers with.
    you have to be careful if you do the following and are not an experienced weldor, it makes it much easier to blow holes in the pipe, and create restrictions in the pipe.
    Also I find a very small champfer on each tube end helps to get a good penetration and makes it easier to follow the seam for me. Just some ideas....peace
  • carbon
    Procrastinator
    • 388
    Nice!
    - Ben
      • 9191
      I may have to promote this to an article...
      • bob442
        Show Me Your KITS!
        • Nov 2008
        • 1305
        Very nice! so ahhh.... where the finish product?
        • NateD4
          • Mar 2011
          • 576
          I think somewhere I saw a special tube cutter for headers.
          What kind of tubing are you working with stainless or mild steel?
          As the old adage goes "Measure twice, cut once" (I prefer to measure thrice).
          • bob442
            Show Me Your KITS!
            • Nov 2008
            • 1305
            i dont think a pipe cutter will work out when you have to cut a 180* j bent on a angle. i ended up using a small chop saw and a belt sander to make the cuts perfect, and tune the cut a bit too.
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              I've had good luck with the pipe cutter, but I do see where it wouldn't work in all situations, you have a chop saw, so life is much easier for you, I have a cut-off wheel and an angle grinder...
              • bob442
                Show Me Your KITS!
                • Nov 2008
                • 1305
                i just cant picture a pipe cutter working on a 45* angle on a small radious U bend, wouldnt it just walk all over the place for the cut?
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  for most of what I've been working with, a pipe cutter has worked great, the main issue is that of clearance to bring the cutter all the way around the pipe.
                    I typically used a hack saw or a sawzall but before it broke my exhaust chain cutter worked well....
                    good tips, another good one is to not use fluxcore.. haha
                    • ericjon262
                      build it.
                      • Jan 2010
                      • 2218
                      Yeah, if I had argon available, you better believe I would use it.
                      • Christos05
                        • Dec 2011
                        • 28
                        How much that cost to make your Own headers?. I want to make my own headers on my 3.4 J-body. but I know nothing! How much can cost to me?
                        • ericjon262
                          build it.
                          • Jan 2010
                          • 2218
                          probably not much less than the cost of buying a set already made... the thing is though, in my case no-one makes nice headers for a Fiero that aren't crazy $$$ I know some people like the truleo headers, but from the pics I have seen, they look like junk...
                          • Kaiju Senso
                            • Sep 2010
                            • 82
                            Yeah the Trueleo headers seem like good quality to me (and Francis is a great guy to work with to get them how you want) but the welds are a bit ugly. I have to say though that my 3400 sounds great with them and I didn't have to make them myself.
                            • ericjon262
                              build it.
                              • Jan 2010
                              • 2218
                              for me, it was more than just the welds, it was also the way the collectors were designed, that being said, I have no idea how much the truleos cost, I just know the stuff from west coast fiero is insane $$$
