Horsepower gain from tuning alone? Maybe more too?
  • J-Ri
    • Feb 2012
    • 5
    I've got a '01 Impala with the 3.4L, got the car extremely cheap and I'm not looking at putting any real money into it. I already have HP Tuners Pro, and I know you can gain a lot of power just by properly tuning the V8s (LS- mostly). Has anyone done just a tune on these V6s? If so, what power gain did you see? I just don't want to buy more credits and only gain a few HP. The 3.4 in the minivans make 5 more HP and torque than the Impalas, so I can at least gain that, but if that's the max, it's not really worth it to me. This is my daily driver now, and I know that without spending thousands I'm not going to make it a fast car. It just feels SOOOOO slow the first time I drive it after driving my supercharged Cavalier for a few days.
    If it would help much, I would install a larger throttle body, the stock one is obviously more restrictive than the air intake hose and the upper intake, but also larger than the valves and runners. What do you think about a larger TB? Do these engines have problems with the TB icing up if the heater is bypassed?
    I had also thought about slightly higher ratio rocker arms, but from what I've heard about the camshafts on these engines, I don't think I should add any stress to the valvetrain. What are the opinions of those with experience with these engines?
    Can the rev limiter be raised safely and would it do any good? I raised it by 750 RPM on my Ecotec with no internal modifications and have had no problems in 2 seasons of drag racing and 40,000 street miles, and a few people though even raising it by 750 RPM was conservative for the engine. Yeah, I know, apples to oranges... Another thing is that my Ecotec pulls all the way up to the rev limiter, while my 3400 seems to taper off about 500 RPM before it shifts. I don't have a real dyno, I used a dyno app for the iPod, wideband O2 and datalogging to make a pretty good guess at what to change in the tune on my Cavalier. So I don't know exactly where I am from peak power when it shifts, but looking at the dyno sheets I could find online, I think it would keep the engine more in the powerband if I raised the rev limiter and shift points by a couple hundred RPM.
    If I do decide to tune it, can the stock injectors deliver enough fuel at the current pressure? Is there a slightly higher pressure fuel pressure regulator that fits in the stock fuel rail? If not, I assume I could just add a low pressure FPR in the return line, say 5 or 10 PSI, and raise the fuel pressure by that much? Does the stock FPR raise the pressure beyond what it does at atmospheric pressure if pressure is applied to the vacuum port?
    I also considered water/methanol injection, I built a full system for my Cavalier for about $20 (yeah, twenty $US) and I wouldn't have to modify the controller's program much to add one on my Impala. The pump and injectors were used and free (and I've got enough for a couple more systems). It helps a lot with the increased IAT on the supercharger, but I'm not sure how much on N/A. The websites that sell kits claim big gains on N/A (for example 16 HP on a Mazda 3L) just by bolting on the kit, but I'm not sure how much I believe that.
    If anyone has suggestions for other cheap (not necessarily fast or easy) mods that might help with a good tune, I'd love to hear them. I'm an automotive technician, an electronics hobbyist and I'm pretty good at welding and fabricating. Very little is out of my grasp here, I just want to do this cheap because I'm planning on selling this car in the next year or two. I have as much fun building a fast car as I do driving it, so time is not an issue, just money. I know nothing I add will increase the value of the car much, and nothing (or very little) would swap over to the engine I will have in my next car.
    Thanks in advance for answers to any or all of these questions!
    Jason
  • mickaz
    • Aug 2004
    • 350
    the tuning will help you get more ponies but the main thing about tuning is efficiency you gain from a stock tune. the main problem with the GM v6 is the exhaust. They are very restricted. If you start with an header and you tune it you will a get substantial power increase. and your injectors are fine till about 210HP after that i would start to consider bigger injectors.
    Mike 60degree addict.
      • 13525
      From what you have said, leave it alone.
      • Merc6
        • Oct 2011
        • 23
        Originally posted by J-Ri View Post
        ...I'm planning on selling this car in the next year or two...
        *Spark plugs (OEM)
        *Ignition wires (OEM)
        *Cabin and engine air filters (OEM)
        *Engine and trans oil change with filters
        2013 Black Granite Metallic Chevy Cruze ECO 6MT (DD)
        2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car)
        1998 Sandrift Metallic Buick Century Limited (Traded in)
        • J-Ri
          • Feb 2012
          • 5
          Thanks, I'll give just a tune a try, and might try a set of headers depending on what I get from tuning alone. I'll post whatever results I get.
          What did I say? Could you please elaborate? The only thing I can think of that I said was that it was extremely cheap. It was so cheap because the previous owner didn't want to replace the lower intake manifold gasket, 4 wheel brakes, a fender and do a full tune-up. It's now in perfect mechanical condition, so while it cost me little more than the value of the 4 new tires it had on it, it's a very nice car, and in better shape than most other W-bodies I've seen (and I work on tons of these cars). I'm also not doing it cheap because I can't afford to make it fast, I'd just rather use the cars portion of my discretionary income on something that's not a 4 door sedan.
          Originally posted by Merc6 View Post
          *Spark plugs (OEM)
          Already done except for the cabin air filter. Still great advice, it's funny how often people put big money into add-ons while neglecting maintenance
          • TGP37
            Shadetree Engineer
            • Jul 2011
            • 1027
            What about fuel filter? That is a big one. 3 times in 4 years I had changed a filter for a friend and twice it resulted in restoring top end power.
            And if replacing the fuel filter really did help with top end, start preparing for a fuel pump swap. Cause the one you got is gonna die soon. They don't like fighting a clogged fuel filter and when they are free of it, they burn up/break in days/weeks.
            Put seafoam in the fuel/oil and treat the intake as directed. it will help clean up the injectors, remove some oil coke garbage and clean up the intake valves some.
            Spraying the MAF with cleaner helps. These sensors get dirty and then give a false reading, leading to poor performance. Avoid oiled air filters.\
            Drive the car around while scanning it with the HPTuner. If you post a log with the basic parameters there are plenty here who can decifer the data.
            btw, Sappy is a straight forward guy. He said that for professional reasons.
            You said the previous owner didn't want to replace the LIM. That means it is leaking coolant into the oil. The oil can boil off coolant but it leaves behind a gritty particle that chews into your bearings/journals etc.
            Stoip driving it ASAP. Replace the LIM, drain and flush the coolant. Replace the T-Stat. Then check oil pressure when fully warm.
            If you are serious about mild tuning, I can help somewhat. But you gotta make sure your sensors are working proper first. If just 1 important sensor is giving a false reading, the whole tune process is junked.
            • J-Ri
              • Feb 2012
              • 5
              The fuel filter looks fairly new. Around here they rust at least a little bit the first winter they're driven, this one is spotless. I checked both fuel pressure and exhaust backpressure to assure no fuel or breathing problems, neither changes as the power drops off. It's also not a big drop off, but I can tell it's going past the peak power, it's just the last few hundred RPM before it shifts. I'll do the fuel filter one of these days anyway, but I don't think it's plugged.
              I completely agree about the fuel filter taking out pumps, the pump in most newer vehicles can build 120+ PSI if it's deadheaded, and I've seen 2 fuel filters so plugged that the engine would start if I let the pump run until the fuel rail pressure was up to spec, then the pressure would drop off at idle and the engine would stall within minutes. How they drove the car until it was at that point is a mystery to me.
              I checked the fuel pump waveform and it is good, and the guy I bought it from never replaced the fuel pump. That indicates to me that he has replaced the fuel filter on a regular basis.
              I don't believe in sea foam as a maintenance fluid. It is mostly ethanol, light hydrocarbon chains and a small quantity of water that is absorbed by the ethanol, you don't want alcohol and gas in the oil, and they are already present in the 10% ethanol blend fuel I use. It does work for intakes, but not that great. I have seen it used to free stuck rings on an engine once, but unless the alternative is tearing the engine apart, I would never use it in the oil. As an automotive technician, I have seen so many people use it (and other parts-store cleaners) and still have problems which were solved by an air induction flush kit from BG Products. It has a 12oz can each of fuel injector cleaner (you run the engine on it with a canister that has compressed air fed into it), a fuel additive, and an intake cleaner that is sprayed into the intake as the engine is run. It does a great job, and while a bit more expensive, is more than worth the price difference. I also cleaned the upper an lower intake while I had them off, and also cleaned off the intake valves while I had the pushrods removed for the lower gasket. They weren't that dirty, but are nearly spotless now.
              I did clean the MAF sensor, but it lowered the reading by .1 g/S (close enough that I'd say it was unaffected by the cleaning), about what I expected from how clean it was, but I cleaned it while I had it apart anyway.
              I meant to also say that I replaced the lower intake gasket before I drove the car, and the smaller problems in the first week I was driving it. The lower intake gasket wasn't leaking that bad internally either, when I did the gasket the insides had none of the whiteish-brown goo that you get with excessive water/coolant in the oil. I also clean what sludge I can out of the head/block area, then rinse it off with a few quarts of new oil, then after everything's back together, I drain and refill the oil before starting the engine, then get the engine up to temp, flush the coolant, then change the oil and filter. Anything that was in the old oil is out of it after that. Ironically, the gritty particles you get in oil when mixed with coolant is the carbon that's stuck to the walls of the oil passages that's cleaned off by the alcohol in the coolant. That's why I would never use seafoam in the oil except as a last effort.
              I did take a quick look at all the sensors and they read what I expect them to. The LTFT is +2-5% for most cells, nothing above 10%. I appreciate the offer for help, and may take you up on it. I tuned my supercharged Cavalier with no problems (fake 2.5 bar MAP tune), but one never knows what they'll run into on a different project. I'll post the tune when I'm done. I was a bit surprised that there were none in the HP Tuners repository,
              This paragraph isn't directed at any one person, and this isn't the first time I've said it on various forums. When I said I'm an automotive technician, I meant it. I try to say that anytime I post on a new forum so that people don't waste their time telling me things I know . I'm not a mechanic, not a grease money, not an experienced DIYer. I'm the one that fixes the drivability problem that a few other shops haven't been able to fix. Often times that comes down to maintenance that's been neglected.
              I'm really only looking for cheap options to add a little power, not restore power that it's missing. It's slow compared to my built up street/track car, not slow for what it is. I do sincerely appreciate the time everyone took to give me maintenance advice (>99% of the time that would be better advice than how to add power), but unfortunately it's wasted on me.
              • TGP37
                Shadetree Engineer
                • Jul 2011
                • 1027
                Good, it is easy when working w/ someone who knows their stuff.
                What I forgot to add about the Seafoam treatment was time. I know that stuff isn't best in the oil but I use it just prior to oil changes. 1/3 can in the gas with a full tank, 1/3 in the oil and 1/3 sucked up. When the gas tank is near empty, I drain the oil and replace with fresh (no seafoam).
                I am going to look into that product you mentioned, BP cleaner. But as of recently, my engine is pretty clean right now.
                As far as tuning goes, finding the best AFR in PE Mode for power (12.5-13.2 area), more aggressive spark advance and fine tune the acceleration enrichment for the crispy throttle. If you are using HPTuners, they have a forum with a ton of info specific to your vehicle class. It is easier said then done but that's the basics of it.
                You can tune the transmission some. Boosting line pressure slightly can net a faster, more firm shift with a little more grab and go feeling.
                Opening up the exhaust and adding a CAI has done well for many 60v6's
                Tuning is more effective gaining power when the mechanical parts were modified, changing the volumetric efficiencies, etc. The mods will net some power, the tune will make those mods more effective.
                • Merc6
                  • Oct 2011
                  • 23
                  BG is what GM actually uses right?
                  • Z3500
                    • Jul 2011
                    • 42
                    I have read this paragraph several times, and it makes no sense to me. An auto-tech who fixes cars by doing maintenance that other people have not done and other mechanics have overlooked. But you are not a mechanic, so you just tune the cars or change air filters?
                    Not trying to be a dork, but I don't understand.
                    And just doing a custom tune to get a little more HP is going to give you very little "seat of your pants" noticeable increases, marginal at best. I would bet that is why Ben said to leave it alone. If you are going to sell it in a year or two anyway, it would be more trouble than it is worth.
                    • bob442
                      Show Me Your KITS!
                      • Nov 2008
                      • 1305
                      X2
                      • J-Ri
                        • Feb 2012
                        • 5
                        Yeah, I think they say 500 miles before the oil change on the can. I did use it a few times on my old '86 Chevy pickup (350 V8 ) before I had heard what it's actually made of. I had no problems as a result. The odometer quit rolling over the 1,000 position and above, but I estimate 60,000 miles since then (8 years), probably 175-180k total miles on the truck. I didn't like the idea of adding fuel and alcohol and never used it in oil again. It does do a great job of cleaning out carburetors on small engines.
                        For the fuel injector cleaner and air intake cleaner, you have to use a special canister. There are some reasonably priced ones on e-bay. http://www.ebay.com/itm/Westward-Fue...item1c1c1e9099 I have absolutely no experience with that brand or that seller, but something like that is what you need. If you get one, make sure it comes with a spray nozzle that's rated to at least 60 PSI, you need it for the intake cleaner. The BG stuff works well enough that I would personally buy a canister for personal use if I didn't have one at work. It takes about an hour to do it right, so if you have a shop do it for you twice, you've more than paid for the canister in savings on labor. If you end up getting the canister, PM me and I can give you the list of directions and some tricks I've learned. If you don't follow the directions it doesn't work that great (mainly it's heat activated, so the engine must be hot when starting the chemicals). Instructions don't come with the cleaner, it's only intended to be sold by and used by shops who already have the instructions (BG won't sell directly to you), but I'm sure you can buy just the chemicals from a local shop that uses it. It's 3 steel cans in a clear plastic shrink wrap.
                        The transmission tuning is what I expect I may need help with, I tuned and retuned my Cavalier so many times every time I changed anything, I think I can do the engine part just fine. The only real differences are that this one has the MAF sensor and my Cavalier is a M/T.
                        I'm not sure, I'm an independent tech, but I wouldn't be surprised if they do.
                        What I meant is that small things that often get overlooked by mechanics, like carbon buildup on the valves can cause hard starts and hesitation or a fuel filter restricted just enough that no amount of stationary revving will drop the pressure, but it will drop off on long hard acceleration. Most of what I do is diagnosing electrical and drivability problems, then fixing them, even if I'm changing a fuel filter or doing an induction system flush. The fix is often something anyone could do, it's finding what's bad on the first try that a lot people have trouble with. For example, just today I replaced a bad VVT solenoid on an '01 Lexus 3.0L. I was the 4th person to try to fix it. Had the oil been kept clean (these engines are known for sludge buildup problems anyway), the solenoid wouldn't have become plugged up and stick occasionally, giving symptoms exactly like a stuck open EGR valve. It took all of 10 minutes to find (after driving for 45 minutes before it finally acted up), and once the part was delivered 10 more minutes to install it. Not that complicated, but being educated about all the systems on a vehicle is a must. This is what auto techs do. A mechanic is basically just someone that just does physical labor, or replaces parts with little or no idea why. No fuel pressure? Replace the pump. Engine running rough? Do a tune up. It may seem like a small distinction, but in the auto repair industry there is a big difference between mechanic and technician.
                        I know that just a tune may not be that noticeable, but an increase is an increase. A year or two is 30-60k miles for me (Another misunderstanding that was entirely my fault ), 90% will be in this car because I don't want to wear out my built race engine on the street. If I was driving 100 miles a week, I would agree that it wouldn't be worth it. Fuel efficiency also increases with a good tune, so just that is probably worth it. Driving that much in a car you don't like isn't fun. I live 15 miles from where I work for someone else, and 25 miles from my own shop that I'm starting. I have to go back home at least between the two because I have dogs. I also have to run and get parts for my shop as we're not in anyone's fast-delivery area.
                        • TGP37
                          Shadetree Engineer
                          • Jul 2011
                          • 1027
                          data, data, data and lots of it.
                          Because you want the trans to shift at the right RPM so you can make best of the range where greatest power (or efficiency) is at. For the most part that is obvious but I also considered where the rpm was dropping to after the shift. Don't want to shift into a bad RPM range by mistake. It is easy to think why someone would want to shift at 2000 rpm at 15% throttle, for quiet cruising. But the trans might shift to low beyond the stall convertor limit.
                          So I made charts. Lined it up and had it shift so the next gear landed at the lowest reasonable RPM for cruising. So when I am cruising around the engine will never be below a specific rpm limit, but it will be just above....that was for low throttle.
                          just past that I wanted the torque behind the wheel. Throttle from 20%-50% was in an RPM band that had peak torque. I had the trans shift so 20% throttle was around the low side of the torque curve and 50% throttle was around the higher side of the torque curve.
                          50% to PE Mode was a blend between the last range and PE Mode. PE Mode was set to shift at max HP (not torque) which was much higher RPM. So each gear had it's reasonable max point. You may choose to have 1st gear shift sooner just to get into 2nd faster if you spin tires easily. Those little things were tweaked over time.
                          I used virtual dyno info and street logs to roughly get my own torque and hp curves vs rpm they were in vs throttle positions. If you can get a real dyno read out that would help trans tuning A LOT for accuracey.
                          note, I took it to my own extreme with excel and lots of log hours. You could leave most alone and just tweak the PE Mode shift points. Note that a scheduled shift at 5500 RPM will actually be more like 5800 RPM. So don't shift at redline, always 300-500 rpm below it.
                          Common changes I have seen over at HPTuners forum are disabling torque limits, firming up line pressure, gently speed up shifts**4t65, zero out TCC in 2&3, bump up downshift TPS points and find the best redline RPM (safely)
                          btw, I am just a hobbiest, not a paid professional....yet, lol. I hold no liability for any damages resulting....because sometimes sh!t happens when an older car is altered. No one will know if your seals can not handle a small boost in atf pressure. Or if the weak point will tolerate a slightly firmer shift. From what I gather, the odds are slim if you do not cut corners. Saying that, I tuned anything like it was spark advance on the edge of knock.....carefully over time in small steps.
                          to be fair, I shreaded my 4t60e. But I also was pushing 12psi of boost uphill in 3rd for wot logs. I am now a 5speed. So I dont need to worry about that stuff anymore...lol
