I have searched... sorry...
  • Fireball
    • Sep 2010
    • 128
    Wow thats a funky UIM!
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      mars, will you check to see if that UIM bolts to a earlier LIM?
        IIRC, the gen 4 intakes do NOT work with the gen 3/3.5 and earlier motors.
        • Mars
          • Apr 2004
          • 826
          ^true, it mounts via 8 bolts vs. 6. Not gonna fit older stuff. It looks very 3500ish.
          • ericjon262
            build it.
            • Jan 2010
            • 2218
            thanks, just thought I would ask.
              • 13530
              #21
              I have the adapters.
              • ericjon262
                build it.
                • Jan 2010
                • 2218
                #22
                I'll start a new thread...
                • alpinestar10
                  • Apr 2010
                  • 194
                  #23
                  I wonder if the 3900 upper intake has the same bolt pattern as the 3500 did since i just sold a machined adapter for a 70mm 4.3 trottle body, Should of had my guy make a cad drawing of the adapter if it worked.
                    Um read above.
                    • alpinestar10
                      • Apr 2010
                      • 194
                      #25
                      Sorry but Umm read my statement better i see where you got confused but im talking about the throttle body bolt pattern hence me using the term adapter.
                        my bad
                        • alpinestar10
                          • Apr 2010
                          • 194
                          #27
                          Its all good. Relooking at that throttle body neck bolt pattern it is almost spot on i could be wrong though, Whats the opening on the 3900 75 or 70?
                          • CNCguy
                            Bisong eater :P
                            • Dec 2003
                            • 1017
                            #28
                            It is the same pattern but the LX9 pattern is on an angle while the LZs are straight. The LZs have a 75mm opening and the LSx TB matches up nicely with an adapter.
                            MinusOne - 3100 - 4T60E
                            '79 MGB - LZ9 - T5
                            http://www.tcemotorsports.com
                            • Mars
                              • Apr 2004
                              • 826
                              #29
                              How cool would it be if the 2007 Montana manifold fits the engine bay of a third gen Camaro... NICE turbo header !!
                              • Mars
                                • Apr 2004
                                • 826
                                #30
                                Thought I would update this..
                                It does fit.
