fiero cam help
  • mixedupamx
    • May 2012
    • 2
    fiero cam help
    IM getting ready to drop a fresh GM 2.8 shortblock into my 85 fiero GT and need to get a cam for it. I wondered if anyone here has used any aftermarket cams and which one worked well as far as extra power with the stock computer. I dont want to get into a new chip and etc. just looking to optimize whats there. If the stock fiero gt cam is the best option I will go with that. looking to stay with a hyd. flat tappet cam. thanks for any help!
    • 13531
    I wouldn't use the word optimize in regards to using the stock tune, as it is not optimal on a stock cam, let alone any other cam. If you want the best cam for the stock tune, something around a 260 grind is going to work best. WOT-Tech has the ability to spec a cam for any application, including bone stock, and John has done some flat tappet cams in the past. He goes by ForcedFirebird on here. If you want a shelf cam, I can get the comp 252 grind is probably the closest available. That is going to be the best possible cam for the stock tune however.
      Live life 3.7mi at a time
      • 4555
      Don't waste time on the 252, I'd at least do a 260 for a shelf cam, but a custom cam is going to be better. If you don't mind doing some extra machine work, there's more lift to be had than .440" as well (260 cam is 260/260 .440/.440)
      • mixedupamx
        • May 2012
        • 2
        thanks FF was looking at an ISKY 262 cam that seemed like it would work but wasn't sure if the computer would freak out with it. I dont want to get into any machine work and etc. just wanted a little more over stock. will probably mill the heads when I get the valves done for a little more squeeze and I might do a bowl cleanup port job too. I just cant bring myself to ever put a totaly stock engine in anything.
        • Mars
          • Apr 2004
          • 826
          I'm not 100% on this but can't you use the 94-95 3100 rockers which are the 1.6 ratio in that motor to gain lift ?
          Someone here will confirm...
          • geoffinbc
            Iron Head Enthusiast
            • 5831
            Buy the COMP 252 or 260 K kit and some Magnum 1.6:1 roller tip rockers and call it a day. I could not be more satisfied with a single product I put on my Trooper!
              • 4555
              Your ECM will run fine with a 262, but it will be better if you put a new chip in it to take advantage of the better breathing.
              It has been done. You have to shave off the bottom of the pedestal, Joseph Upson did it a few years back. Really unnecessary since there's 1.6 rockers available as a direct fit.
              Yup. The Comp 260 is what I would go with. We can get them even though they aren't listed on the WOT-Tech store, for a competitive price.
                • 13531
                94-95 3100 don't have a pedestal, so they drop right on.
