Torque Master Plugs
  • LA1 Z24
    • Jul 2004
    • 24
    Torque Master Plugs
    Well I was looking at a Fiero site that came up in another post in this forum and came across these plugs. They are 'highly recommended' yet I have never heard of them...Anyone have any more info on them?
    and you can find the spot where i learned about them here...http://www.fierosound.com/34engine/3400details.htm
    towards the bottom...look for the tiny pic of plugs and click it
  • v6h.o.
    • 1418
    i'd just stick with AC Delco's.
    Colin
      • 13525
      Plugs either work or they dont. Its only job is to ignite the mixture. Get the proper plug for your car (heat range) and stick with it.
      • LA1 Z24
        • Jul 2004
        • 24
        Well I picked up some AC Delco Rapidfires....#6...Was that the right plug? I looked on the comuter @ work and there were no rapidfires listed for the LA1..But I noticed that some 3.1 plugs are the same as 3400 ones...So I assumed the #6's would work becausethey are listed for 3.1s...Was I right?
        BTW Colin this is TroublesomeZ24
        • GPXSS
          • 588
          the 60deg V6 hates torquemaster plugs.. stay away from them.
          if you want a plug like that, get the Halo plug. www.haloplugs.com or www.halosparkplugs.com
          I modify stuff
          • brian89gp
            • 554
            The twin rotor motor in the RX-7 actually uses a similar designed plug on I think the trailing edge. The leading edge are just regular plugs.
            I was talking to a rotary fanatic about the torque master plugs actually and he mentioned that the RX-7 has 2 of 4 of the plugs that have the same design due to rotor clearance. When he takes it to the track or dyno he replaces all plugs with colder, regular plugs because 1. they foul out due to being colder, 2. they are cheaper, 3. they work just the same.
            • ProjectMM
              • Mar 2004
              • 170
              halosparkplugs. sounds interesting, where are they sold? and do they work with the batch fire system? not many plugs do, besides AC/NGK. has anyone used them? in a newer car?
              2002 Pontiac GrandAm GT1
              3400 v6
              TOG headers
              RSM 62MM T-body
              FFP underdrive pulley
              GRANATELLI MAF
              Ported upper intake
              MSD DIS 4 ignition box
              MSD Wires and coils (pending)
              Venom high flow fuel pump (pending)
              • GPXSS
                • 588
                I used them in my 3.2 hybrid and my 3200 and they worked great. You contact whoever through the web address and order them.
                I used the torquemaster plugs and my engine hated them.. the spark gap was way too wide and idle/response was crap. Never had that problem with the Halo plugs.
                I modify stuff
                • DEI37
                  • Jan 2004
                  • 516
                  Those are interesting looking plugs. What real benefit do they offer?
