S&S 3400 header pinhole from the factory.
  • blackbombshell95
    Kaiō-ken X 10
    • Jun 2004
    • 1386
    Has anyone else seen this before? I was trying to figure out why my 95 GP won't idle when warmed up.
    Sorry for the cellphone pic. The hole is on the o2 bung weld.
    I take it this is something that I have to remove the rear header to repair?
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    I hope that they haven't been coated, if they are, there's not much that can be done other than JB weld or RTM.
    • blackbombshell95
      Kaiō-ken X 10
      • Jun 2004
      • 1386
      That is ceramic coated. What is RTM?
      • ericjon262
        build it.
        • Jan 2010
        • 2218
        Return to Manufacturer.
        • blackbombshell95
          Kaiō-ken X 10
          • Jun 2004
          • 1386
          Not likely gonna happen.
          • ericjon262
            build it.
            • Jan 2010
            • 2218
            I've heard that it's damn near impossible to weld up stuff like this after the coatings have been applied. good luck.
            • onefastV6
              • Sep 2005
              • 880
              As it is just a pinhole, I would take a dremel and wire wheel the coating in that area. Then get a mig welder and tack a small bead on it to seal it up, which should be able to be done with the headers still in the car. Lastly get a can of VHT spray paint and a small paintbrush, spray the VHT on cardboard and dab on the VHT with the brush.
              BTW: Isn't that the EGR port?
              They must have been made on a Friday
              2000 Grand Am GT
              2011 Chevy Impala
                • 13530
                That sounds like the best way to do it. JB weld probably won't hold up to the heat.
                  I would go with what Phil said too.
                  As for the RTM, that's like calling Packard Bell tech support (an old IT joke I heard).
                    • 13530
                    Packard bell is a joke by itself:P
                      Yep, just tack it with a MIG, clean it up well and put some high temp paint on it. I had a few small pinholes in mine and that took care of them.
                      • trotterlg
                        • Feb 2011
                        • 326
                        I doubt patching that pinhole will fix the idle problem. Larry
                          • 13530
                          Its right before the O2, which is going to throw off the readings. Makes sense to me that it fucks up in closed loop.
                          • blackbombshell95
                            Kaiō-ken X 10
                            • Jun 2004
                            • 1386
                            That's what I thought also but its 3 inches away from the O2 sensor. The cam will only idle in open loop.
                              I highly doubt this is the problem with the idle... Is it just me who sees the fact that that bung is plugged and there is no O2 sensor there...
                              What else is done to the car? Different cam? Raised idle to compensate? Checked IAC system? checked TB Plate closing properly? Tuned VE and MAF to correct for the cam?
