Pre '99 timing set install
  • 19Cutlass94
    • Apr 2005
    • 770
    Hey guys, I had a 2004 timing set on my car, and I think it has stretched some, as I don't remember that much play. So I'll be switching to the beefier pre '99 setup. Any tips or suggestions on the crank gear? Haven't done that before so I'm not exactly sure what to expect.
    Thanks!
    Sent from my iPhone in some random spot of Texas.
    3400/Getrag 284 5spd
    350/NV3500 5spd
    2014 Chevrolet Malibu LS
  • geldartb
    The Situation
    • May 2004
    • 1994
    i used a socket big enough to cover the gear and fit around the crank bolted that down until i had a decent amount of threads and used the stock crank bolt to finish the rest.. forget the longer bolt i used but the threads matched.
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
    • 19Cutlass94
      • Apr 2005
      • 770
      Thanks!
      Ive done some research, and found some interesting specs..
      The chain I have now, is only 8mm wide.
      The 94-99 chain is 11mm wide (http://www.rockauto.com/info/SealedP...tml?222385.jpg)
      and the older chain, pre 94, is 15mm wide (http://www.rockauto.com/info/SealedP...tml?222372.jpg)
      So my question is, could I run the older chain, and will it fit in the cover? I know every suggests the GM 99 chain, but if this is thicker, could I run that set?
      Summit has it for $42. (not a cloyes set, its a clivite/sealed power) (need to order parts from there anyways)
      350/NV3500 5spd
        • 13533
        not compatible
        • caffeine
          • Jan 2012
          • 1489
          Is there a reason the aftermarket cams aren't available with the 3-bolt iron head cam sprocket flange? IIRC the iron head chains just appear much beefier and are something like twice as thick.
          '86 Fiero, 3500, 4-speed
          • 19Cutlass94
            • Apr 2005
            • 770
            not compatible
            Copy that.
            So then these would be the parts that I need?
            Cam Sprocket 10166350
            Crank Sprocket 14074400
            Chain 10166352
            Dampener 10166353
            (thanks 3400-95-modified )
            350/NV3500 5spd
