Lx9 Flow data..
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    Lx9 Flow data..
    Looking to find some info on how much the stock 3500 heads flow intake/exhaust per 1k rpm N/A. Does anyone have those numbers?
    1,000rpm=?
    2,000rpm=?
    3,000rpm=?
    4,000rpm=?
    5,000rpm=?
    6,000rpm=?
    7,000rpm=?
    ..... kind of an odd way to measure flow? and wouldn't it be dependant on cam timing among other variables?
      Do you want mathematically derived numbers or actual flow numbers?
      Actual could be done but like Robert said it would really depend on the cam, exhaust, porting, ambient air temp, runner temp etc...
      You could run a long (like 8') piece of 4" PVC to the throttle body with a pair of pitot tubes in the middle of it. With some programming of an Arduino, a differential pressure sensor, a temp sensor and a MAP sensor you could get those numbers.
      That's basically how Pitot flow benches work, and how HVAC guys measure CFM in duct work.
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        I would accept mathematical numbers. Kinda would ballpark me in I guess lol .
        Robert, that's just me, very odd character lol
        • 1988GTU
          LB62LHObbqftmfw
          • Nov 2005
          • 2475
          Dave,
          U happen to have those numbers?
            One would need some fairly advanced sym software. I'd ask Ben and see if he can get that sort of info from his setup.
            I can get volumetric efficiency % from DD2K but that's about it.
            • 1988GTU
              LB62LHObbqftmfw
              • Nov 2005
              • 2475
              May I ask for that please? Thanks!
              • trotterlg
                • Feb 2011
                • 326
                If you got 100% cylinder fill at 7,000 rpm you would flow 432 Cubic feet per minute. Larry
                  Live life 3.7mi at a time
                  • 4555
                  Correct, but you can have over 100% VE
                    • 13531
                    Whats DD2K say VE is on a stock 3500 at 7k?
                      50% @ 7K
                      78.1% at 3500 is peak
                      I'm showing 193HP @ 4500 and a blazing 257 TQ at 3K though
                      That's a little odd...
                        DD2003 does the same thing for any 60V6 engine i build in it.... stupid amounts of low end torque, but reasonable HP estimates.
                          • 4555
                          50% @ 7K
                          Interesting.
